Kaitospeed Merchant Sale
Genuine BREMBO MAX BRAKE DISC
If you are looking for affordable replacement brake disc, but would prefer something better than your standard disc, we would recommend Brembo Max.
Brembo MAX provides improved braking performance under all pressure and speed conditions tested in the laboratory and on the road. It also ensures greater safety in wet road conditions.
The new high performance brake disc guarantees shorter braking distance and provides improved braking performance under all conditions.
Maximum Monitoring of Wear
One of the Brembo MAX grooves has been specially designed to permit a direct, rapid check on brake disc wear. When this groove is no longer visible, the recommended minimum thickness level has been reached; an indication that users should replace the worn disc. Even so, the braking system will still continue to function thanks to the remaining grooves. A similar wear indicator groove, positioned exactly opposite on the internal disc braking surface, ensures that the disc is perfectly balanced.
- Latest stock shipment from Brembo Italy (Jan 2008)
- Brand New in Box
Item Include :
- 1 Pair (2units) Brembo Max Brake Disc for Front Application
Plug and Play on :
Honda Civic EG6, EG9, Dohc Vtec, Sir EK4, Vti EK3, ES 2001-2005
Specification :
- Diameter : 262mm
- Thickness : 21mm
- PCD : 100 x 4
- Centre Hub Hole Width : 64.2mm
Lowest Price in Market :RM480/pair
Genuine Brembo Max Marking, Beware of Imitation!
T&C
- SKYNET Courier Service - RM20 Flat Charge to Whole Peninsular
- PM for COD details
- Installation is NOT included
- Promotion Nett Price
- Goods Sold are not returnable. Please make sure the correct model is ordered
PM or Contact 016-7442406
Kaitospeed Performance Autoparts
www.kaitospeed.tk
CLICK HERE to check out more promotion items!
- Brand New in Box
Item Include :
Plug and Play on :
Specification :
- Diameter : 262mm
- Thickness : 21mm
- PCD : 100 x 4
T&C
www.kaitospeed.tk
