Dear All,
We have supply for the following brake rotors upgrade/replacements for various car application.
Brembo Max:
Brembo MAX provides improved braking performance under all pressure and speed conditions tested in the laboratory and on the road. It also ensures greater safety in wet road conditions.
Currently we only sell for:
Brembo Max is suitable for Honda civic ES 03-05. 4 x 100 pcd 262mm size
RM 750 front pair. With a promosion price.
The rest is out of stock.
Brembo Sports:
This is the basic line of the High Performance Brake Systems program. It is a braking system consisting of an integral disc, available drilled or slotted
High carbon cast iron discs
Discs with HC coding are produced using special cast iron with a high carbon content that guarantees better performance and less risk of noises compared to normal cast iron thanks to a better damping factor
HIGH CARBON CAST IRON DISCS
High carbon cast iron guarantees top performances and less noise due to a higher damping coefficent.
TÜV/ABE CERTIFICATION
Most of the SPORT line is composed of discs with ABE approval granted by the German Ministry of Transport on TÜV certification. This is because Brembo actually develops and manufactures its entire range of brake discs in its own factories at very high quality standards ensured by stringent checks on the whole production process.
Size of brembo sports rotors-262mm (high carbon slotted or crossdrilled)
Price: RM 1,400. per pair. (We only have for honda ES 03-05. The rest is out of stock).
Regards,
Ali G
Brembo Max:
Brembo Sports:
Regards,
Ali G
