FILTERMAG Magnetic Oil Filtration !!
(TOTALLY REUSABLE, So Buy 01 and Keep it Forever !!)
WHY USE THIS ?
* ALL engines make harmful steel chips as they run. These chips wear off rings, valves, valve seats, cam shaft, bearings and other precision parts of the engine!
* These tiny particles are so small that the oil filter will not trap them. The filter is designed to stop only large particles.
* These tiny particles damage the most critical parts of your engine, leading to unplanned costly repairs.
* The Society of Automotive Engineers says that the tiniest of particles that pass through the filter are the most harmful to engines.
THE SOLUTION:
** Magnetic Fluid Filtration! **
Installing a FilterMag onto any fluid canister filter will immediately improve oil filtration efficiency by 1000%!
HOW DOES FILTERMAG WORK?
* FilterMag holds onto the filter with its own magnetic power! You simply put it on the outside of your standard filter. No tools required.
# Steel plates block stray magnetism, preventing interference with sensitive engine electronics.
# Steel plates also focus the magnetic energy to the inner canister wall.
* FilterMag’s Magnetic Flux Field passes through the filter canister wall and captures the harmful steel particles that are circulating in the oil as it goes through the filter.
FILTERMAG RESULTS
* Engine oil is much cleaner and will last longer.
SS Series (Street Type - 75 lbs. Pull Force)
**The SS Series of FilterMAG™ is geared towards the oil filtration needs of light duty automotive, light truck and imported motorcycle applications. One of our four models in the SS Series will fit virtually any light duty vehicle on the market.**
PRICE : MYR$250.00 (small type - for most Oil Filters)
RA Series (Racing Type - 150 lbs. Pull Force
** The RA Series of FilterMAG™ can be used for both standard and Hi-Performance engines. This baby is built for the demanding needs of large diesel trucks, racing, and heavy duty applications. The RA Series provides extra power where its needed most.**
PRICE : MYR$330.00 (small type - for most Oil Filters)
REMARKS : FOR BIG SIZE OIL FILTERS, PLEASE EMAIL TO ENQUIRE ON PRICING & AVAILABILITY
CONTACT US
KAITENAZ RACING SDN BHD
8, JALAN PJS 11/16,
BANDAR SUNWAY,
46150 PJ, SELANGOR D.E.
TEL : +603-5635 5351
FAX : +603-5631 6351
EMAIL : [email protected]
[email protected]
WEBSITE : http://www.KAITENAZRACING.com
WHY USE THIS ?
THE SOLUTION:
FILTERMAG RESULTS
CONTACT US
8, JALAN PJS 11/16,
BANDAR SUNWAY,
[email protected]
