Can... cos ae114 is a 4wd drive corolla.... the ae111, 114 and 101 SPRINGS are interchangeable.... the ABSORBERS however, for ae114 is different from 111 and 101 cos 114 is shorter... 114 is a 4wd corolla.... it uses rear dif assembly similar to S13/ crv and impreza.
If u wanna make sure.... visit or check TRD catalogue.... Ae111 and 101 shares the same mechanical/ handling part numbers... most of em... even to the exhaust systems too....
But i won't recommend you to take wagon springs... cos it will be too plush, you will tend to understeer if u use wagon springs.... cos it have been designed for the extra rear weight... using it for a sedan can be considered not practical for cornerings.
