Just an opinion for you to ponder further...
Rebuilding is a matter of luck in getting it right, moreover a proper tune is also something you need to think about. It also applies to importing a brand new Tomei or N1 engine. All it takes is one bad tune to take you back to square one.
If I have the cash let's say 100k, i would try to source a modded halfcut (specially arranged thru the junkyards) with all the goodies which has the turbo(s), wiring, cams, all the pipe work, intercooler, ecu, gearbox, clutch (triple plate?), 320km/h meter, etc etc...if your lucky you may also find the matching rear end. You know how the Jap's loved to mod it to the maximum.
Im sure with the extra $$$ left after the purchase of the halfcut, would be for any parts replacement if it is damaged. This way i have more spares which can sell if not required.
...im just too careful how i spend my hard earned money especially nowadays (need to burn fuel more efficiently). Hope you managed to find your direction. Cheers!
I beg to differ.
Rebuilding an engine is not a matter of LUCK. It's the engine builder's skill.
See whether he has enough patience, measures everything correctly and
most importantly experienced in building an engine.
And as for tuning, they're are pretty capable tuners in Malaysia.
100k and you'd buy a second hand engine from a halfcut shop ?
[PIMPIN],
100k : OS RB30 short block for RM70k, balance : buy ecu, Tomei head products, turbo(s), etc.
And for another RM42k you can get a OS 6 speed sequential gearbox
or Mine's Stage 2 complete engine for around RM100k.
or buy a NEW N1 block for RM 7k, Tomei 2.8 stroker - RM 18k,
Nismo engine bearings - Tomei complete headwork parts (cams, valve spring, metal gasket, etc) - Tomei oil pump RM 4k+, N1 water pump RM 1300,
Tomei Baffle plate new twin/triple plate clutch RM 5-6k, Tomei fuel rail - RM 900,
labour to build the engine ECU - Radiator - < RM 6k for ARC smc55, Turbo - price depending on model, spec.
and some other small things, etc. Still have plenty of change from Rm100k.
