Intel Pro/Wireless 2915 802.11abg Mini PCI Wireless Network Adapter for Notebooks
With your wireless network card, you can access wireless networks, share files or printers, or even share your Internet connection. All of these features can be explored using a wireless network in your home or office. This wireless LAN solution is designed for both home and business use. Additional users and features can be added as your networking needs grow and change.
Your Intel PRO/Wireless 2915ABG Network Connection adapter is compatible for 802.11a/b/g wireless standards. Operating at 5 GHz or 2.4 GHz frequency at speeds of up to 54 Mbps you can now connect your computer to existing high-speed networks using multiple access points within large or small environments. Your wireless adapter maintains automatic data rate control according to access point location to achieve the fastest possible connection. provide enhanced security measures using 802.1x network authentication. All of your wireless networks connections can be easily managed by Intel PROSet/Wireless. Intel PRO/Wireless profiles provide enhanced security measures using 802.1x network authenticatio...
Product Specification:
Adapter Type Network adapter
Form Factor Plug-in module
Data Transfer Rate 54 Mbps
Interface Type Mini PCI
Wireless Yes
Antenna Interface Connector Hirose U.FL-R-SMT mates with cable connector U.FL-LP-066
Dual-diversity Antenna On-board dual-diversity switching support for systems designed with two antennas
Radio ON/OFF control5 Supported by both hardware and software
Connector Interface MiniPCI Type III edge connector
LEDs Output Link, Activity
Data Link Protocol IEEE 802.11b, IEEE 802.11a, IEEE 802.11g
Operating System Microsoft Windows* XP (Professional, Home, Tablet), 2000
Wi-Fi Alliance Wi-Fi CERTIFIED* for 2.4 GHz and 5 GHz band, WMM*, WPA*, and WPA2*
WHQL Yes
MiniPCI Compliant Yes
WLAN Standard IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, 802.11d, 802.11h, 802.11i, and 802.11e
Architecture Infrastructure or ad hoc (peer-to-peer). Ad hoc mode limited in some IEEE 802.11a frequencies.
Security
- Authentication
- Encryption LEAP,2 WPA,2 802.1X, EAP-TLS, EAP-FAST, PEAP
CKIP, TKIP, 128-bit and 64-bit WEP, Hardware AES2
Product Safety UL, C-UL, CB (IEC 60590)
Compliance Cisco Compatible Extensions*, Wi-Fi Alliance
Manufacturer Part No. WM3B2915ABGNA
Dimension 1.8 in x 2.4 in x 0.2 in (HxWxD)
Warranty 1 Year Manufacturer
http://img289.imageshack.us/img289/1642/extremepcgear8hc.th.jpg
Selling price RM150.00
Interetsd??? Please contact +6019 281 1600. COD at Project Station Sri Hartamas
Thanks for viewing
Wireless Yes
WHQL Yes
Security
- Authentication
Thanks for viewing
