INNOVATE LM2 Wideband Lambda Monitor
powerautohauz
The LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, ODB-II tuning software, or a flash/chip programmer, an LM-2 is the tool you need to dial in maximum HP. The meter’s award-winning digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-2’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
- Patented “Direct Digital” Wideband Technology
- Wideband O2 Compatible with ALL fuel types
- Single or Dual Channel Version Available
- OBD-II Scan tool- read/clear DTCs and log up to 16 channels of CAN OBD-II Data
- Log directly to SD card (included)
- Playback log data on screen and/or with powerful LogWorks software (included)
- Large high-contrast graphics LCD
- Built-in RPM converter (direct frequency or with optional inductive clamp)
- 4 fully-differential analog inputs
- 2 configurable linear analog outputs
- Positive lock connectors for all connections
- Innovate MTS serial IN and OUT
- USB connection to your PC
The LM-2 also features two fully programmable linear analog outputs to connect to analog gauges, dyno computers, ECUs, piggyback controllers, and other devices with analog inputs. Analog output 1 comes setup from the factory ready for narrowband simulation; analog output 2 is configured as 0 volt = 7.35 AFR and 5 volts = 22.39 AFR. With the provided LM Programmer software these analog outputs may also be configured by the user.
Bakuso Racing Sdn. Bhd.
No.21, Jln PJS 11/24,
Bdr Sunway.
47500 Subang Jaya.
Operation Hours: Mon~Sat 9am~7pm
GPS: Latitude 3.067118, Longitude 101.601951
Click Here For Google MAP Location
Land Mark:
Same row with Kedai Tayar Silverstone Teck Meng, REV PERFORMANCE, Millennium, 2 shops beside SAMURAI RACING.
For serious buyer please Whatsapp or SMS
Desmond 017-396 8567
Email us : bakusoracing@gmail.com
Dealing method : Pos/Courier everywhere in
Malaysia including Sabah, Sarawak, Brunei, Indonesia, Thailand, Singapore and all area in Asian.
