Recently, a friend of mine has gotten direct contacts for the sales of Innovate Products and also for the technical / after sales support as well. As some of you are aware, even the Innovate LM-2's pricing that he's selling is very competitive compared to anywhere u see be it online or at the local shops.
Here is the list on some of the other Innovate Products that he carries.
** Remark: Please take note this is not the complete list as he carries ALL Innovate Motorsports Products. For full listing, please visit http://www.innovatemotorsports.com **
http://www.innovatemotorsports.com/xcart/image.php?productid=16293
No.1 - Price: RM 1,920.00
Item: Innovate LM-2
Description: The LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day
http://www.innovatemotorsports.com/xcart/image.php?productid=16235
No.2 - Price: RM Call for Info
Item: Innovate DB-Blue Gauge / LC-1 Kit
Description: This kit comes complete with the patented award-winning LC-1 Wideband Controller, DB-Blue Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
http://www.innovatemotorsports.com/xcart/image.php?productid=16244
No.3 - Price: RM Call for Info
Item: DL-32 Datalogger and Sensor Controller
Description: The DL-32 is a complete vehicle-mounted data-logging system for advanced engine tuning. The system is anchored by Innovate's award-winning digital wideband air/fuel ratio technology, but also includes flexible sensors for RPM, MAP, temperature, duty cycle, and analog inputs.
http://www.innovatemotorsports.com/xcart/image.php?productid=16282
No.4 - Price: RM Call for Info
Item: RAD-1
Description: The RAD-1 (Rollover Avoidance Device) is a precise Digital Inclinometer that features user-programmable tip points and a loud progressive warning tone (like a backup warning). The display shown X (Pitch) and Y (Roll) angles, and it's got a few other cool features, but it's mostly the audio warning that really makes it useful. Now you can keep your eyes on the rocks, trail, or road, while keeping an ear out for the RAD-1.
http://www.innovatemotorsports.com/xcart/image.php?productid=16239
No.5 - Price RM Call for Info
Item: LC1+ Kit
Description: The LC1+ kit includes an LC-1 wideband controller with O2 sensor, plus an SSI-4 multi-sensor interface. Used in conjunction with LogWorks, running on a laptop or PC, this setup allows you to record and analyze 5 channels of data. These channels are Air/Fuel Ratio, and any four of the following: RPM, Injector Pulse Width, Throttle Position, Driveshaft/Wheel Speed, or Boost/Vacuum. All channels can be configured for external 0-5V or frequency
http://www.nzperformance.co.nz/store/images/uploads/New%20images/LM2%20med.jpg
There's a brand new product from Innovate. It's called the LM-2. For the old price of a plain old wideband system, you now get a full OBD-II aware data logger, code scanner, and display system. The LM-2 plugs into your OBD-II port, so it can read, display, and log any of the information your ECU knows. Plus, it's a wideband air/fuel meter. Plus, it logs it all to an SD memory card, so you can upload the results to your PC for analysis.
The LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, ODB-II tuning software, or a flash/chip programmer, an LM-2 is the tool you need to dial in maximum HP. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-2’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
The config screen:
http://www.autojunctions.com/images/stories/lm2screen.jpg
1) The LM-2 Kit (Single Wideband O2) includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, analog in/out cable, ODB-II/CAN interface cable, SD memory card, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide.
2) The LM-2 Duo Kit (Dual Wideband O2) includes the LM-2 meter, (2) Bosch wide-band oxygen sensors, (2) 8 ft sensor cables, cigarette-lighter power adapter, analog in/out cable, ODB-II/CAN interface cable, SD memory card, USB cable for PC connection, (2) weld-in bung and plug kits, LogWorks software CD, and quick-start guide.
It's really a must have for all you DIY guys or for Workshop use!
So for those who runs stand alone engine management system and or tunes their own cars this Innovate LM2 is the ideal and perfect item to have.
Item (LM2 only) is priced COMPETITIVELY at RM 1928.00
for bulk purchases, price is negotiable.
Please contact Eugene @ 012.2808.692
email : [email protected]
Item: Innovate LM-2
Item: RAD-1
Item: LC1+ Kit
- Patented “Direct Digital” Wideband Technology
- Wideband O2 Compatible with ALL fuel types
- Single or Dual Channel Version Available
- OBD-II Scan tool- read/clear DTCs and log up to 16 channels of CAN OBD-II Data
- Log directly to SD card (included)
- Playback log data on screen and/or with powerful LogWorks software (included)
- Large high-contrast graphics LCD
- Built-in RPM converter (direct frequency or with optional inductive clamp)
- 4 fully-differential analog inputs
- 2 configurable linear analog outputs
- Positive lock connectors for all connections
- Innovate MTS serial IN and OUT
- USB connection to your PC
The config screen:
The LM-2 is available in two different kit configurations:
