How to install EGT..
powercable
Guys, sifus
Can anybody explain here how to install EGT (greddy)?
I mean how to tap the manifold, sensor and
such..
TQ.
Hi power,
The sensors for the EGT would have been threaded already, so you just need to tap the Exhaust Manifold with the appropriate threader. You would need to drill the ex manifold, thread it and screw on the sensor bung. A relative easy job if the turbo is off.
If the turbo is still on, it gets tricky... you wouldn't want the shavings to fall in to your turbine housing and mess it up rite. Trick is to start the car just a litte when you are doing the threading so the shavings get blown-up and use a vacumn to suck off any loose shavings. Still its a delicate sugery. Have fun!!
wooosh... thats some detailed explaination... didin't know exhaust temp is drilled into the manifold... all the while tot its put after the turbine... hahaha. Now come to think of it... logic also... else it wouldn't be accurate if after turbine!!
Yes, after turbine temp is off by approx 100c, actual how much I oso dunno.. after conversion your monster also need EGT!! xD
