max is using spring.. pro is using hub ar if i not mistaken....max is softer... but easy to break when press the clutch down is not that loud....... pro when u press the cltubh the sound is loud, a bit harder.. but not as hard as hypersingle clutch... more stronger.. more reliable wotn break that easiely.... price is aroun the same... around RM3700-RM3900...
i think what fred means is that the screw that tie down the pressure plate
to the flywheel easily break cos the ori's come with 8mm nut.usually they
change the nut to a 10mm to make it more durable.
is normaly man.. u have to rev to 2k rpm to smoothly move ur car... i alreayd sent a pm to u.. u will understand more on that..... yeah... the nut cant stand.. u cant lauch and balance with twin plate clutch
so if u are new and not use to hand brake during up hill get ready to mati engine wkakakaka... i mati engine so many time when i first change from hypersingle to twin plate.. but it grips like a ulu glu... no slip at all
