Help me !! AVCR ? WASTEGATE ?
bertdeen30
im going to install a AVCR ..but beforei t. . wanna ask if i got waste gate ..then how ? what they will do ? waste gate open..avcr need to set as same as waste gate ? is that wasted?
do AVCR cut boost let go air that time go sound ? from solenoid or valve?
waste gate and AVCR which better ?
if 2 the same time if will work better ?
any idea ?
me no clue , no idea.. want to know more about ..aVcr , profec 2 and other ..about boost cut ..~or etC
if your wastegate is 1 bar setting... then your minimum boost is 1 bar... AVCR can up your boost... cannot go lower than that.
AVCR and wastegate are 2 different things that have different functions. Do a lil' bit of search and you'll find out their functionality.
wat AVCR?
if u refer to some wiring diagram for AVCR, they got written the wiring diagram for normal turbo and wastegate. for example, Apexi avcr
:retarded:
