- Joined
- Mar 10, 2006
- Messages
- 23,305
- Points
- 1,648
HALTECH Sprint 500 ECU with complete Harness
Description:
Engine Suitability:
• 1 to 8 Cylinder engines
• Normally Aspirated or forced induction
• Load sensing by throttle position or manifold pressure (MAP)
• Sequential, semi-sequential, batch or multi-point injection patterns
• Distributor ignition systems or multi-coil systems
Trigger Types:
• Hall Effect
• Optical
• Inductive Magnetic Reluctor
Trigger Patterns:
• Single Pulse per cylinder
• Multi-tooth
• Bosch Motronic
• Ford
• GM
• Honda
• Mazda
• Mitsubishi
• Nissan Optical
• Subaru
• Toyota
• Volkswagen
Features:
• Windows 2000, XP, Vista compatible software
• Real time programming, instant hesitation free adjustment while engine is running
• Fully user definable 16 x 16 mapping
• Tuning via Volumetric Efficiency (VE), Injection time
• Selectable onboard internal MAP sensor rated to 150kPa (up to 1.5 Bar or 22psi boost)
• USB and CAN Communication Port
• Custom sensor calibaration allows for most factory sensors to be used
• 2 x User programmable outputs
ECU Fixed Outputs:
• 4 x Fuel Injector outputs (for high impedance injectors only (ie: above 8Ω)
• 4 x Ignition outputs
• Tacho
• Thermo Fan
• Fuel Pump
ECU Programmable Outputs:
• 2 x Programmable Outputs
ECU Inputs:
• Air Temperature
• Aux Rev Limiter
• Coolant Temperature
• Manifold Absoloute Pressure
• Roadspeed
• Throttle Position
• O2 Sensor (Narrowband or Wideband)
Functions:
• CAN Communication
• O2 Control
• Over Boost
• Gear Setup
• Decel Cut
• Transient Throttle Enhance
• Rev Limiter
Correction Tables: Fuel / Ignition:
• Air Temp Correction
• Barometric Correction
• Coolant Temperature Correction
• Injector Dead Time
• Map Correction
• Post Start
• Prime Pulse
• Wide Open Throttle
• Zero Throttle
Miscellaneous:
• Tune can be password protected in software
• Small and compact design
• Rugged anodized aluminum casing
Power Requirements:
Source: 8.6 to 16.5 Volts DC
Consumption: 360mA @ 12Volts DC
Physical Dimensions:
ECU Dimensions Length: 134mm (154mm with MAP nipple)
Width: 64mm Height: 28mm Weight: 195g (0.43 lb)
The Platinum Sprint 500 Kit includes:
Platinum Sprint 500 ECU,Platinum Sprint 500 Flying Loom, USB Cable, Programming Software CD,
Quick Start Guide, Instruction Manual (on CD), Haltech Sticker
Selling price are from RM2xxx only.
Interested please contact us @
We are located in Bandar Sunway
D's Garage by Hanzo Racing
37, Jalan Pjs 11/9 Bandar Sunway
46150 Petaling Jaya
Malaysia
Tel: 03-5612 6117
Email: [email protected]
016-997 3300 (JC)
019-389 1881 (MATT)
Please visit our website : Hanzo Racing Malaysia
Please Visit Our Garage online : Clearance SALE!!!
Description:
Engine Suitability:
Trigger Types:
• Hall Effect
• Optical
Trigger Patterns:
• Multi-tooth
• Bosch Motronic
• Ford
• GM
• Honda
• Mazda
• Mitsubishi
• Nissan Optical
• Subaru
• Toyota
• Volkswagen
Features:
ECU Fixed Outputs:
• Tacho
• Thermo Fan
• Fuel Pump
ECU Inputs:
• Air Temperature
• Aux Rev Limiter
• Roadspeed
• Throttle Position
Functions:
• CAN Communication
• O2 Control
• Over Boost
• Gear Setup
• Decel Cut
• Rev Limiter
• Map Correction
• Post Start
• Prime Pulse
• Zero Throttle
Miscellaneous:
Power Requirements:
46150 Petaling Jaya
Malaysia
Tel: 03-5612 6117
016-997 3300 (JC)
019-389 1881 (MATT)
