The New Driving Force in Engine Management
The Haltech Interceptor is a totally new “piggy back” ECU designed to work in parallel with your existing factory ECU.
The Interceptor provides tuning of fuel mixtures, ignition timing, boost levels and many other features. The Haltech Interceptor is installed using a universal type wiring loom and tuning is performed on a laptop with user friendly Interceptor software for Windows. As the Haltech Interceptor works with the factory ECU, you need only tune where necessary, maximising power whilst maintaining factory levels of economy, idle quality, cold start etc.
Performance has never been achieved so quickly, easily and affordably.
Haltech Interceptor
Interceptor Kit Contents:
Interceptor Unit (ECU)
Main Wiring Loom (flying lead)
Programming Software
Instruction Manual on CD
Accessories:
MAP Sensor (1, 2 or 3 bar)
Electronic Boost Bleed Valve
Boost/Fuel/lgnition Trim Module
Fuel/Ignition Tuning
16 load sites * 16 rpm sites
User configurable load and rpm axis sites
-100% to +100% fuel adjustment range with 0.4% resolution
-16 to +16 degree ignition range with 0.25 degree resolution
Dual switch selectable fuel, ignition and boost maps
Tuning done on laptop with fast, intuitive windows graphical software
Physical Specifications
Compact, light weight, high temperature, rugged water proof
housing and connectors
Supplied with 1m loom for flexible installation
Feature Highlights
Closed loop boost control with variable boost with RPM
(consistent boost levels with varying conditions)
Configurable to user adjustable boost/fuel/ignition trim for user
adjustment as required or fast adjustment tuning
Flexible high speed data logging
Configurable to monitor injector duty cycle for safety
Configurable to monitor actual ignition timing for safety
Input/Output Options
4 configurable analogue voltage inputs (can be set to MAP, MAF,
TPS, User trim etc.)
3 configurable analogue outputs (can be set to output clamped/
intercepted MAF, MAP etc.)
4 configurable digital inputs (can be set to digital/reluctor crank,
frequency MAF, user switch, injector DC, ignition timing etc.)
4 configurable digital outputs (can be set to output digital/reluctor
crank, frequency MAF, boost control, water spray control etc.)
designed to work in parallel with your factory ECU.
timing, boost levels and many other features with newly
designed Interceptor Windows Software. As the Haltech
where necessary, with the factory levels of economy, idle
quality, cold start etc being fully maintained.
and affordable. The Haltech Interceptor has been fully tested
on many makes and models, with the range of supported
vehicles set to expand rapidly.
The Haltech Interceptor has been fully tested on many makes and models, with the range of supported vehicles constantly being expanded.
Current Supported Vehicles:
* BMW Mini
* BMW Mini Supercharged
* Ford BA Falcon
* Ford AU V8 / XR6
* Ford EF 6 Cyl
* Ford EL 6 Cyl
* Ford EL V8
* Ford Transit 2003
* Holden Astra Turbo
* Holden LS1
* Chev / Corvette LS1
* Holden VN V8
* Holden VR V6 Auto
* Holden VR / VS Auto
* Holden VT V6
* Holden VT V8
* Holden VX V6
* Holden VZ V6
* Honda Accord Euro
* Honda Integra Type R
* Honda Jazz
* Hyundai Excel
* Hyundai Tiburon
* Mazda 6 MPS
* Mazda MX5 1999
* Mazda MX5 SE Turbo
* Mazda RX7 Series 5
* Mitsubishi 3000GT / GTO
* Mitsubishi EVO 6, 7, 8, 9
* Mitsubishi Lancer CC
* Mitsubishi Magna
* Nissan 350Z
* Peugot 206 GTI
* Subaru Forester
* Subaru Liberty
* Subaru WRX
* Toyota 1JZ
* Toyota 2JZ
* Toyota Corolla A112R Sportivo
* Toyota Corolla 4AG
* Toyota ZZE122R
* Toyota Hilux 2000-2005
* Toyota Landcruiser 93-03
* Toyota MR2 MRS
* Toyota Wish
* Toyota Lexus G300
* Volkswagon Golf GTI
Supported models continually updated!
With so many new innovative features, the opposition will be left behind.
Detail: http://www.haltech.com/interceptor.htm
Spec: http://www.haltech.com/downloads/InterceptorSpec.pdf
Actual picture:
Reason for selling: Car was accident, need some money to repair (Tuned for stock EVO6)
Price: RM 1300 (brand new at N1 Racing about RM 3k, selling more than 1/2 price man!
Contact no: 0129660788 - David
Haltech Interceptor
Accessories:
Feature Highlights
* BMW Mini
* Ford BA Falcon
* Ford AU V8 / XR6
* Ford EF 6 Cyl
* Ford EL 6 Cyl
* Ford EL V8
* Ford Transit 2003
* Holden LS1
* Holden VN V8
* Holden VR V6 Auto
* Holden VT V6
* Holden VT V8
* Holden VX V6
* Holden VZ V6
* Honda Accord Euro
* Honda Jazz
* Hyundai Excel
* Hyundai Tiburon
* Mazda 6 MPS
* Mazda MX5 1999
* Mitsubishi Magna
* Nissan 350Z
* Peugot 206 GTI
* Subaru Forester
* Subaru Liberty
* Subaru WRX
* Toyota 1JZ
* Toyota 2JZ
* Toyota ZZE122R
* Toyota MR2 MRS
* Toyota Wish
* Toyota Lexus G300
Actual picture:
)Contact no: 0129660788 - David
