H22A thread
selling honda accorrd sv4 GAB AVCS adjustable abs .
9 month old , student car use 10km a day .
RM 800 neg
012-2198668 , msn [email protected]
cod at kepong jesco , i utama to puchong
no pic
hi taiko ..long time no chat with u in MSN ...don know u still remember me or not... my friend was insterested on ur GAB adj. absorber would like to hv some info from u...is it the hi/lo adj. abs. ? RSONE MOTORSPORT like this ? .....how's the condition ? price still can nego ?
if u online give me a nudge la bro ^^
i have the following for sale, from BB1 H22a (location: butterworth).
1. complete set of head, valve, spring , cover and all for H22A.
2. port & polished both intake and exhaust chamber, very nice and smooth engine response, no problem, as i used it a few years.
3. 4WS control unit also available.
& other parts for BB1, my BB1 sold already, left all the extra parts here.
interested pls pm me.
accord sv4 2.0 auto year 98 selling 38k cannot nego
all i can say very nice ,
is my mother friend car .
if you really really wan to buy accord sv4 only call me. 012-219 8668
this car is tip-top.
v-kool and leather , if don wan leather also can ! change with my car !
does anyone using o know the mod of short shift for H22A?
pls help if any sifu out there.....:adore:
thanks......
info from magazine saying the all h22a r using the DC sports short shift adapter.....did anyone know o can give any command o this issue....:adore:
anybody know where is a good chop shop in JB area got H22A manual? price range around 4-5K. thinkin of switchin my B20A5 to H22A
refer to my siggy
hi all sifu and h22a owner.........................i want to take some opinion from ur guys....does anyone here have done port n polish b4???? hows the performance after pnp??? isit courage or encourage to do this pnp to my virgin h22a???.........cos heard only the b-series done pnp the most and not for h22a.....................................
Bump: hi all sifu and h22a owner.........................i want to take some opinion from ur guys....does anyone here have done port n polish b4???? hows the performance after pnp??? isit courage or encourage to do this pnp to my virgin h22a???.........cos heard only the b-series done pnp the most and not for h22a.....................................
(Bump: hi all sifu and h22a owner.........................i want to take some opinion from ur guys....does anyone here have done port n polish b4???? hows the performance after pnp??? isit courage or encourage to do this pnp to my virgin h22a???.........cos heard only the b-series done pnp the most and not for h22a.....................................)
The result must be same.. b16 and h22a...
i want to know too... any dyno test after all the works???
come on.....
Bump: (Bump: hi all sifu and h22a owner.........................i want to take some opinion from ur guys....does anyone here have done port n polish b4???? hows the performance after pnp??? isit courage or encourage to do this pnp to my virgin h22a???.........cos heard only the b-series done pnp the most and not for h22a.....................................)
come on.....
Bump: :biggrin: one moment please.. i just replace my auto h22a (gearbox only) accord cd6 to manual(not lsd,) the ecu is 3 socket.. how to switch off d4 light in speedometer.. hampeh!!! blink, blink... any body has h22a auto diagram or ecu wiring diagram??? its different perfomance with my ecu beside manual ecu??.. im not replace the original auto ecu.. thanks guys...:proud:
Dear Forummers,
My H22A is from an accord halfcut. Does anyone know whether the Red Top H22A Piston is higher compression?
If I change to the red top pistons, will I need to change the other parts too? Conrods, crank, etc... do I need to balance my engine if I change the pistons?
Anyone have the item product code? dun want to buy the wrong items...
Dear Forummers,
hello bro, the red top (or type s) pistons are 11:1 while others are 10.6:1 so the type s pistons are slightly higher compression.
You dont need to change the con rods unless you are doing some serious build or change to even higher comp or bigger pistons.
the part number should be xxxxx-P5P-xxxx.
hope that helps.
Thanks.
Bro, Do you have the full part number for the piston? So, just change the pistons, Rings only?
BTW, I understand that some of the H22A have different type of write pins for attaching the pistons to the conrods. some are floating type and others are press in types. how do I know which one I have?
i wanted to know those parts that different between black top H22A and the red top H22A also...
just found a forum n read ... RED TOP type S H22A using floating type pin ...black top non floating ....just wondering ....if i swap the whole red top engine in ...without the wiring (red top OBD2) n use back all my present sensor n wiring ...n put in a rechipped ECU ..to run the engine ..is it possible ?
we got a forum ..do join us @ http://h22aoc.20.forumer.com
hiii... my friend has a H22A but the vtec does not on.. The vtec usually ON at 5,000rpm but usually it will be on 5,200 ,5,400... 5,800 or will not come on...then the check engine come ON..when he check it blinks two short times and two long times..so its no 22 (VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch ) ...when you switch off the engine and start again, the check engine goes off...the car has no Vtec controller....
1) things that done :
change new oil press switch
still the same
2) change oil pump
still the same
3) change Vtec solonoid
still the same
sooooo...whats the problem???? please help.. :confused::confused::confused:
still the same
2) change oil pump
still the same
still the same
may be u can refer to this link:
http://honda-tech.com/showthread.php?t=1292106
also check the wiring at the ecu to see if any wires were loose there.
juizeebrain : ok thanx brooo.. i give it a try... i pity my friend...its been 1 year he is driving without the vtec ON..will give you a report later:wavey:....
What will happen when VTEC on ? , How to on the VTEC ? .. Auto car and Noob here
Hello.guys...i got a mugen F22B extractor. any one who are interested can PM me TQVM.
Honda Accord CD5 2.2 (M) - H22A (VTEC) for sales
Manufactured : 1995
Colour : Gold
This is a local model from Kah Motor.
Basically the entire car is stock standard from interior to exterior.
All switches and functions working perfectly.
Clean interior.
All accessories still available.
This is the full spec model - it comes with an amplifier and a sub-woofer.
Original stereo is not working anymore, replaced with an AddZest double din CD/Cassette player.
Recently upgraded the original engine to a H22A with a manual gear box (JPJ Endorsed) - '09.
Electronic climate control from the half-cut - '09.
All major bushing replaced with new ones (OEM) in '08.
Suspensions were upgraded to GAB suspensions in '08.
Price : RM 28000
Contact : Jon - 012 3753445
A thread every 60 seconds
