GSM Car Alarm System
LiLSaInTs
Item : GSM Car Alarm System
Description :
- GSM cell phone barrier
- Built-in Siemens GSM module (2 band) or Simcom module (4 band)
- Remote engine start / stop (optional)
- Trigger alarming (power-off, door open, bonnet open, shocking)
- Remote trunk release
- Activate / Deactivate immobilizer
- Comes complete
Main Features:
- No limited for alarming distance, ramble all over the world
- GSM car positioning Technology
- Alarming phone auto-dial directly to your phone at hand
- Real-time car inside situation monitoring
- Yelling to the attacker no matter wherever you are
- Door lock/unlock, Oil/Power shut off via your mobile phone
To give you a deeper idea, here I would like to give you a detailed description on the function :
1. First, you need a SIM card to put into the alarm, so that your mobile can call the alarm ( send instruction the alarm, and receive signal from alarm )
2. Then your can control the car anytime, anywhere.
3. If someone enter into your car, the alarm will call your phone, when you receive the message, you can speak and warn the people in your car through your mobile anywhere via the speaker of the alarm, you can cut the power/petroleum through your mobile so that people can not drive the car, you can also monitor everything in the car through your mobile anywhere ( what people talking…), you can close the car door/window through your mobile anywhere.
4. The alarm can call the police slinkingly for emergent help
5. Anti-dismantling, anti-stolen, anti-rob
6. IR receive function, no need to get the SIM card out of for charge money.
7. With car moblie function ( optional), you can use the car alarm as a telephone to call anyone (because there is a SIM card in it )
8. With engine start function ( optional ) , you can start the engine remotelly)
Functions and Features in Details
Panic Button
Two emergency telephone numbers can be registered on the alarm. It is advisable to set these numbers to close friends/relatives. If you are in trouble - hit the panic button on the remote and the alarm will automatically call the first emergency telephone number. If there is no reply, it will call the second number. The user can then reset the alarm, monitor the car, send a verbal warning to the burglars or immobilize the car.
Remote Arm/Disarm
The alarm can be set using either telephone or the remote control. If the vehicle is fitted with central locking, this action will also lock/unlock the vehicle. If the alarm is set by telephone, then the alarm cannot be unset by the remote. This feature has many uses:
Someone needs to get in your care when you are away
You aren't sure if you locked the car or not
You lock your keys in the car
Someone steals the remote & keys - if you lock via the alarm, they will not be able to open or disarm the car with the remote
Remote Status
Call the alarm at any time to check the status of the vehicle.
Remote Monitoring
A microphone installed inside the car allows you to listen in to what is happening inside the car from your telephone. Thieves in/around the car will be completely unaware that this is happening.
Remote Broadcasting
By calling the car alarm, it is possible to broadcast your voice through the alarm loudspeaker. This can be used to give a warning to anyone near or in the car.
Car Location
You can track for your car location using gsm service provider to know your car location.(example like maxis friend finder service.)
Anti-tamper
The unit has a backup-batter which works for 7 hours. If disconnected from the power source, the unit will immediately call the registered telephone numbers to warn of the situation. The unit can still be traced during this time.
Anti hi-jack
In the event your car is hi-jacked - do not fight back against the hi-jackers. Instead, let them go and then initiate the anti-hijack feature by calling the alarm from any telephone:
Hazard lights will flash
After 10 seconds the hazard lights will start flashing ,
After 20 seconds, the alarm will start sounding and hazard lights will flashing,
After a further 30 seconds, the car ignition will be cut-off, the vehicle will then be completely immobilised
The alarm will then sound continuously.
Sms function
This alarm come with sms function
Car Locator
Pressing a button on the remote will cause the hazard lights to flash and the alarm siren to sound for 3 seconds. Just in case you can't remember exactly where you parked it !
Silent alarm mode
The silent alarm mode works just like the regular alarm settings except that if the alarm is triggered, the siren does not sound. Instead you will receive just the telephone call warning only.
Auto Hazard Lights
If any door is opened whilst the engine is running, the hazard lights will immediately start flashing. This is useful to warn other motorists that you are stationary and moving around the car. It is also useful when you have children in the car, if the door is slightly ajar, the hazard light signal on the dashboard will bring this to your attention
Q&A
Question about GSM Mobile car alarm system
Question: Did it work if it is no signal?
1. Please be noted that GSM car alarm is nearly same as the a normal car alarm product, the difference between them is GSM car alarm has a net control fuction
2. As you may know that the horn of nearly all the car alarm products will siren after you install the product for the first time So you need to disarm it and then everything will be OK
Package:
1 x GSM Unit
1 x Alarm Unit
1 x Immobilizer
1 x Siren/Loudspeaker
1 x Microphone
1 x GSM Antenna
1 x LED
2 x Remote Control Key Fobs
1 x Auto start device.
Connecting Wires
1 x User's Manual & Wiring Diagram
Condition : New
Price : RM 720
All prices are negotiable
Item(s) conditions: New
Warranty : 1 year warranty
Dealing method: COD / Postage
Location of seller: Puchong, KLCC, Ampang, Keramat, Bukit Jalil, Chan Sow Lin
Contact method/details: 0122332848
Postage service will incur RM 10 in total item cost. (Peninsula Malaysia)
Thanks for viewing my items.
http://img232.imageshack.us/img232/7677/img1067cf0.th.jpg
http://img228.imageshack.us/img228/8621/img1068cw2.th.jpg
http://img136.imageshack.us/my.php?image=img1069eq2.jpg
Where to go to install it? Do u provide installation service? How much to install?
