hope somebody can assist me
1.std BT fuel pump XXX l/ph?
2.std BT injectors XXX cc?
3.lifespan of fuel pump/injectors?
3.idle XXX l/ph pump and XXX cc injector suited for BT to compliment minor upgrades (filter,plug,cables n such)
4.which is a better combo(assuming the good aft pump/injectors is 255 l/ph / 330 cc)?
-std pump+std fuel regulator+std injectors
-aft pump+std fuel regulator+aft injectors
-aft pump+aft adj fuel regulator+aft injectors
-std pump+aft adj fuel regulator+std injectors
currently using no 4 but thinking if no 2 can be done w/o any side effect/chocking?
5.would changing to new pump/injectors but std spec do mmuch in improving fuel system
