Wajafly said:GT20v, :)
Really. As an Auto, no matter how I rev with my car... can't go beyond 6.5K RPM... yeah... even with adjustable cam pulley. Do I have any RPM cut installed in my gearbox or what?
Bigger valve? Hmm... I'm dumb here. :) What's bigger valve and how much is it anyway? Will appreciate if all the sifu here can advice on further NA upgrades. I want to go mod until the end before changing the engine... :)
Oh yeah, please don't ask me change Manual cause the car's not really mine. :)
Wajafly said:Thanks a lot. But before dyno, I think I will first save up money to get better engine management system then only go for a dyno. Cause I feel the SAFC2 and SITC is just not good enough.
Thanks for the mods suggestion. Heard that 4G18 is running on very high compression already. And 4 throttle need Toyota ECU? More stroke length = more displacement right? Will road tax passed?
GT20v said:wajafly,
cant go beyond 6.5k??em weird unless ur max rev is 6.5k la..but maybe....as im not familiar with ur car engine......
bigger valve mean changing the valve to a bigger size..more air flow to engine...more flow + ngam2 fuel + ignition will always create more power........cant advise you coz again..not familiar with ur car engine.......
emmmmm cam,cam pulley..what left for NA tune is just..
more lighten and balance internal
more compression ratio
4 Throttle bodies
more stroke
hehehhe
why dunt you dyno it??? see whats the fruit of your mod...hehehe
Wajafly said:First of all, thank you to everyone who replied to me with great advises like EFN and GT20v.
GT20v, I don't know the cam lift duration but should be around 270 and below maybe? Got no idea and just guessing. The difference is great with P+P. For my Auto, I can say it is faster than standard Waja but NOT good enough to race with any stock GTI or Perdana. However, I am happy with the excellent service and product of MatSpeed.
EFN, thanks for the great tuning reference on FPR setting. Yeah... with the hose disconnected and set to 43, my car chokes like hell and dies off. He (the so claimed professional / engineer boss from power bengkel) says it is a normal procedure of tuning that way. Even when I mentioned what his mechanic did, he says it is normal to him. I had that conversation recorded if you guys don't believe me.
Well, I suspect my engine dies off firstly because of wrongly adjusted FPR setting, but the mechanic seems to think the sensors might be dirty. So, he disconnected the connectors from boost sensor and took the high pressure air gun and sprayed into the sensors connectors including directly at the sensor while it's being attached. That is where I suspect causes permanent damage to my boost sensor on top of my Intake manifold which after that, my car not able to start again even after FPR has been adjusted correctly... Sigh... what a Power-Bengkel it is... I have so much high hope in them based on their nice sweet talking website... Sigh... I am still filling up my Tribunal Court of Claims forms...
Doktahu, I think EFN also mentioned it is about 43.5 PSI for normal Waja. I heard this setting from a friend as well. Funny, I feel good at 43 as well. Maybe a little higher will give better performance? How high is too high? I heard that Waja is running on high compression already. Maybe that's why we run on lower PSI instead?
EFN said:Fuel injection system require pressurized fuel to go through the injectors. ECU will only send signal to open or close the injectors based on whatever input it gets from the sensors. So by default almost all EFi cars uses Fuel Pressure Regulators at the return line path to regulate the desired pressure by the manufacturer. Typically from factory, pressure is always pre-set high to help enriching the mix to ensure that knocking/pinging are eliminated. But too rich a mix will also cause most cars bogs down and slow in response.
For tuners and car enthusiast, the opportunity to use an Adjustable Fuel Pressure Regulator presents some sort of control on the output. This is applicable regardless in what state your car are in - modified or non modified - u still need pressurized fuel else the injectors will not be able to get fuel pass through it. The right amount of pressure will definitely makes the engine happy.
* but nowadays I have seen a lot of new cars does not use Fuel Return System so it has to be that they use some sort of intelligent fuel pump that regulate pressure as required.
if the engine is off that means the fuel pump is off. so no more pressure...it's normal. same like mine.drexchan said:something to ask the sifu here....
i am using the Arospeed adjustable FPR running at 38/44 psi (idling/WOT). I know that the stock FPR should retain the pressure after the engine is switch off, for quite long..
But with the Arospeed FPR, the pressure just drops to nil within few seconds once the engine is turned off.
Is this normal?
