- Joined
- Jul 4, 2006
- Messages
- 1,138
- Points
- 1,648
Wow very detial. Thanks Bro. Hemmm, in my opinion, SAFC n Fuel Regulator are used to control fuel that supplied to ur engine, more fuel = more power, make sense right?
Those ppl who use SAFC to save fuel and increase FC, is it can say that their car will be less power (less hp) compared to those stock engine? Cuz if u tell me better FC (less fuel supply to engine) and increase hp, dont make sense to me leh...![]()
safc is to bluff your ecu to inject more fuel or to reduce fuel..
save fuel and means reduce FC .. not increase.. why better FC and increase HP? normally stock car came with quite rich tune.. a car hp will be highest when complete combustion happen. too rich of AFR will make your car felt boggy, and too lean you will ping your car.... normally stock will be more on the rich side.. so by using SAFC to trim your fuel curve, your car will be better in fuel consumption as u reduced the fuel and better hp when the AFR is close to ideal.
This topic is to share how to bring out a team and type of engine preparation is needed! N if things goes well it might became true that a team 0-100 member will step up!! I should start with race type...
