Fuel consumption of RB25DET?
kahwee81
Kuching,Sarawak
Hi all,
May I noe wat is RB25DET car owner normal mileage for rm10? Coz I jz convert in mine Cefiro A31 in wth RB25DET series 1 engine wth some mode. mode are as below:
- HKS power flow
- big intercool
- mode intake manifold
- walbro 255 fuel pump
- os giken super single clutch plate
- aerospeed fuel regulator (38 psi)
- 2 way lsd
is it normal that Rm10 run only 25 km for mileage? plz advice, thanks!
http://www.facebook.com/?ref=home#/album.php?aid=76883&id=644798994
Re: RB25DET mileage?
Hi Kahwee81,
My ECR33 with RB25DET is having the same mileage as yours with RON97 fuel.
Your A31 project seems to be progressing very well ! Good stuff !
I saw you had the rubber pedals replaced with Razo ones, do you still keep the rubbers ? Can give it to me if you no longer need them ? I cannot find any shop selling them.
Bro, 2500cc fuel consumption should be like this~ :biggrin::biggrin:
bro owtaman, thanks for d creadit! d pedal rubber I din take off coz if take off d pedal level will b lower. And I believe at car spare parts shop hv sell pedal rubber, mayb d pattern is not same like ori. But mine fren's Cefiro A31 oso mode quite same wth me, jz d difference is he tuned d fuel pressure below 36 psi n using cusco 2 way lsd. Im still checking out wat is d problem... Anyway, I'm very happy wth d RB25DET respond n power.
Hi Kahwee81,
How is the fuel consumption of your fren's A31 ? Better than yours ?
Hi kahwee81,
Mine is around 45km/RM10 using RON 97 with daily driving.
Tx.
Hi bro,
For me, Its not soft driving...just normal driving (around 110kmh and be ready for overtake)..
Road from Manjung to P.Remis...a lot of lorry n trailer....sure need lower gear to overtake..
If hard driving...??? Of course alot of petrol maa....
Drive with simple modification....HKS Power Flow, Big Intercooler,OS Giken Twin Plate, Fuel n Boost Regulator,walbro, semi lock LSD...
Bro..u know boost cut for RB25...??? How much maa...???
Tx.
---------- Post added at 01:53 AM ---------- 6 hour anti-bump limit - Previous post was at 01:43 AM ----------
Hi bro,
Tx.
wow, like that u tuned well for ur rb bro! about d boost cut, u mean ori one? if ori is 0.7 bar only n i noe rb ori ceramic turbo can't stand for boost higher then 1 bar i think. do correct me if im wrong....
Dear good person,
U mean the boost cut is 0.7bar??
Huuuhhh...now im runnings almost 0.7bar...
My stock only boost up 0.4 before.....
For me its lowest compare my 6A12TT previous...
Tak boleh tahan looo...
that why i put 0.7....
plus the environment:::::my frenz using SR20 and 4G93T...!!!!
and if u right about 0.7bar is a boost cut,u just solve my problem bro...
JERK PROBLEM!!!!!
Im also heard about ceramic turbo case....(but i like these hussle sound,more romantic than ball bearing).. :biggrin:
Thanks bro...
Still im my planning to upgrade the turbine to RB26 turbine...
I think is 0.7 bar, coz from our meter cluster there show a boost meter which show +7.... ya d ceramic turbo hussle sound very nice that make me fall in love wth it. btw, how many bar did u set for ur fuel pressure bro?
---------- Post added at 01:27 PM ---------- 6 hour anti-bump limit - Previous post was at 01:24 PM ----------
btw, for you all info I did try to keep d rpm below 3k. n d mileage can b xtend more.
Dear good persons,
Currently now running on 44psi...(but i think the setting still not ok)...
Have try (xperiment) untill 70psi...very good response...
Unfortunately, too many people said its too higher...
Drop it back to 44psi...
What r u thinking kahwee...??
Is it mean i need a SAFC...???
Sorry coz lack of knowledge....:rofl:
wah u try untill 70 psi ah?ur fuel regulator can adjust untill dis meh? wat brand r u using now? big o small one? Im not really sure bout SAFC... coz still not yet touch untill that. mayb u can try to take off ur fan and fit in electric fan, then for sure u will gain more HP for ur engine n get faster respond.
Yes bro...
I think its 70psi due to range is 0-100psi..(sorry if wrong info)...:slug:
Use big regulator......
What fan bro...???
Radiator fan...??
Now runnings on big radiator fan with aluminium radiator....
yes, radiator fan i mean. ic, wat fan did u use? n how bout d wiring? use fan controller? did u fit back d radiator cover? wat brand use for d radiator? n may i noe wat is ur average water temp during normal driving?
Kahwee..
Sorry coz late reply...
My radiator fan wiring is parallel with oil cooler fan while thermostat activated.
Yes, put back the radiator cover n my aluminium radiator is from THRASH GARAGE brand:itsme:
I dont know the water temperature reading but it's around 25% in normal runnings (morning) and 50% (afternoon /traffic jammed) based on my temperature indicator.
Tx..
u mean u connect to ecu? im using volvo 2 speed fan, n hv problem wth it. coz dis fan use up alot of electric and made mine ori alternator produce not enough to support d car usage. u brought d fan from zth one is it which is around rm180? o u mode by using japan hc radiator fan?
Bro..
I never touch ECU..
Just parallel my radiator fan with oil cooler fan wiring...
Better u buy a new big(size) radiator fan aftermarket....
Price is around 150-200....
Where is your standard RB25 radiator fan..???
Still using standard radiator..??
:itsme:
Znaw, thanks for d reply! do u mean dis kind of fan? http://www.zerotohundred.com/newforums/engine-and-performance/283058-electric-fan-performance.html
Mine ori radiator fan still hv, but dun think wanna fix back.
By d way mine fuel consumption is getting better, rm10 for 33km.
