Fs: Stromberg (fuel Saver)
All Other Stuff
Stromberg.Fuel
Stromberg Power Booster
A device that install on the spark plug to increase the fire power before entering the spark plug. Made in Germany. Proven safe fuel and boost power. Certified by Bosch Electro in Germany and Automobile Association of Germany. With Warranty.
Website: http://www.strombergpowerbooster.com
Item(s): Stromberg Power Buster
Package includes: 1 set (4x Power Booster)
Price: Retail Price RM179
Warranty: Stromberg Warranty 7 Years!!
Dealing method: Postage / COD
Location of seller: Melaka
Contact method/details: PM
Age of item: New, Unused, Unopen
Contact No: 017-9500798
Item(s) conditions: New, Unused, Unopen
Reason for sale: Stock for End of year
You can test before & after using this Stromberg
Either your spark plug will be HOT or not.. this is the secret of STROMBERG
How to know your car is compatible
· Gasoline engine
· Petrol engine
· Not VVTi, DVVT, i-VTEC or VTC engine
· Must have plug cable on the engine
· Must have spark plug
· Must have either ignition coil or distributor unit
· Compatible with Honda PGM-FI (Programmed Fuel Injection)
Feedback:
Gen 2: http://www.cardomain.com/ride/2250416
Car: Proton Gen 2 1.6 DOHC Auto year 2005
Feedback: Bought Stromberg, Bosch Super 4 Spark Plugs, RON Voltage Stabilizer and RON High Quality 4AWG Ground Cable from Ron. I feel like I am driving a Civic 2.0 Auto VTEC DOHC now. Very good products at very low price. I will surely intro these products to my friends.
More: http://www.strombergpowerbooster.com/feedbacks.htm
SELLING AT RETAIL PRICE RM179
http://www.strombergpowerbooster.com/images/b16avtecstromberg3.jpg
AS LONG AS YOU HAVE PLUG CABLE ~ CAR / MOTORCYCLE / LORRY / VAN
http://www.strombergpowerbooster.com/images/bikeinstall6.jpg
Guaranteed Enhancement
· Increase Power up to 20%
· Petrol saving up to 15%
· Less carbon developed
· Longer plug life up to 30,000 KM (normal spark plug)
· Easier starting anytime
· Smoother engine running
· Almost complete fuel combustion
· Quiet running engine condition
· 7 years warranty
· 20 Minutes installation
http://www.strombergpowerbooster.com/images/websparkx.gif
Want to go faster, further, cheaper?
A low-cost, easily fitted device that promises to boost the performance of any spark-ignited engine. "More or less!" - always an appealing catch-line no matter on what product it is hung! In particular, this phrase is well bandied about in the motor accessory industry as various gadgets are enticingly dangled before a free-spending motoring public.
Many reports have been published on this line and summing them up they vary from a cautiously worded appraisal claiming the gadget in question does all it claims, through to a forthright condemnation. In most cases, time is the acid test. There will always be a certain "here today, gone tomorrow" knick-knackery in the industry but out of this a few really excellent and durable products will emerge.
Just one such "more-power-for-less-petrol" gadget that has stood the test for more than 20 years is the Stromberg high-frequency converter. The claims made for the device - 20 percent increase in performance, 10 to 15 percent saving in fuel consumption, fires oil-saturated spark plugs, a lifetime (yours, not the car's) guarantee - are extravagant in the extreme, you will agree.
However, before being conned with another "wonder" engine reviver we approached several garages and tune-up centres and they all agreed - it worked, and worked well. We tried it out in a very senior Volkswagen Variant pushing close on 200 000km and with an engine consuming 500ml of oil every 300km as it snaked around the country-side. The oil rings on one cylinder were so bad that with the standard ignition the spark plug completely broke down after 1500km and had to be replaced.
The increase in performance was quite marked although it fell short of the claimed 20 percent. Petrol consumption showed a decided decrease in 100km. Prior to the speed restrictions, the converter reduced the petrol bill by 14 percent and with the imposition of the speed limits this has further improved to 21 percent. The oil consumption got another 17 000km behind it and that on the same spark plugs. It is now more a question of topping up the petrol and filling up with oil.
How It Work?
Under conditions of standard ignition, electricity is led into the spark plug via the terminal at the top, down through a porcelain-encased conductorto the "gap". All things being equal, it will jump this giving off a single spark as it does before earthing in the cylinder head. This single spark is themotivating source that initiates and maintains the smooth running of your engine.
From this it is clear that the whole operation is centred around that one little spark plug. If this critical spark can be improved so will the whole performance of the engine. Simple it may seem on the surface of it - just increase the gap and the voltage and, with the fatter spark you will enjoymore complete combustion with correspondingly more power and economy.
To do this you will need a more elaborate, and consequently, a more expensive coil. The result, in a very short space of time, will be burnt and pitted points, a breakdown of the plug insulation, overloading of the condenser and electrical discharges around the distributor or through perished insulation.
Should there be an accumulation of moisture or even an oily film across the business end of a plug, it can lead to a partial discharge, thus short-circuiting the whole object of a higher voltage system. These are the reasons why there has been little or no change in ignition systems over the past quarter of a century.
This then is where the high frequency converter comes into play. To illustrate the working of the converter let us assume the duration of a plug sparkis one second from start to finish with standard ignition. With the aid of the converter there will be half a dozen sparks over the same period.
The net result is almost complete combustion which consequently means more power for the same quantity of fuel burnt, which in turn is going to amount to improved petrol consumption. All this is gained by simply altering the frequency of your original spark. It is a case of "if the first flash doesn't explode the mixture the second one will". The rest of the sparks are used to mop up any left-overs that sneaked past the first two igniters.
"That's all very well" says the belt-and-braces type watching a most convincing demonstration, "but what's it going to do to my engine?"
Quite apart from the fact that the manufacturer guarantees the device in no way harms an engine, what, now we know how it works, can it do?
The coil feeds the converter the designed amount of electricity which it merely converts to a high frequency stream of current. There is no change of voltage or cylinder-head temperature. Besides, with 20 years of acceptance and use to back it up, you can rest assured it would have long since vanished off the market if it failed to do all that was claimed or actually harmed the engine in some way.
The converter is simply screwed into the high-tension lead running from the coil to the distributor just as you would install a radio suppressor. It can be used on any six or 12-volt car, truck, tractor or stationary engine using a conventional ignition system. The fact that your tractor uses power paraffin makes no difference.
The only question remaining unanswered is why so simple and effective a device has not yet become standard equipment? No doubt with the petrol position as it is, such petrol-conserving devices will really be appreciated for their worth.
huaren1978 said:
is it suitable for turbo application? will it disturb the air-fuel ratio thus causing a lean mixture?
Yup, also suitable for all car. Here below got example those who using these Stromberg for their TURBO
GSR Turbo
http://www.strombergpowerbooster.com/images/wiragsr2.jpg
L2S Turbo
http://www.strombergpowerbooster.com/images/PET9717e.jpg
FYI, this Stromberg give more power to SPARK PLUG and this thing will not effect other's thing as air / fuel. It only give more spark power, as a conclusion the car will be more pickup & less fuel consumption. I'll post a demo after this about this Stromberg, you can see the different power & also temperature of you spark plug.
Others Feedback
