- Joined
- Nov 7, 2005
- Messages
- 922
- Points
- 5,018
Interested can contact me 016 2510646
SCAN SPEAK 23W/4557T02 (COME WITH MANUAL) RM2000
Product information
General descriptionCharacteristic sensitivity (2.83V / 1m) : 82 dB
Recommended frequency range : 21 - 500 Hz
Free air resonance frequency, fs : 20.5 Hz
DC resistance, Re : 3.45 ohm
Voice coil inductance, Le : 0.45 mH
Effective piston area, Sd : 232 cm²
Moving mass incl. air, md : 101 g
Mechanical loss, Rm : 2.7 Ns/m
Force factor, BL : 9.3 Tm
Equivalent volume, Vas : 45.6 ltr.
Mechanical Q-factor, Qms : 4.8
Electrical Q-factor, Qes : 0.52
Total Q-factor, Qts : 0.47
Excursion, lin./max. : ±13 / ±20 mm
Voice coil diameter : 50 mm
Rated power handling : 225 W
Net weight : 4.6 kg
Scan-speak D2905/9700 RM1200
The Scan-speak D2905/9700 uses the same hand coated dome and voice coil of the D2905/9500, but uses the motor system of the Revelator. The Symmetric Drive technology eliminates almost all electrical phase shift. The carefully machined top plate minimize air noise and compression. Copper caps act as heat conductors. High power handling is achieved without ferrofluid and improves micro-dynamic linearity. The tweeter has excellent dynamic and detailing capability.
TECHNICAL DATA:
Sensitivity 2.83V/1M 89.5dB
Free air resonance Fs 500 Hz
DC resistance 4.7 W
V.C. inductance 0.01 mH
Power 225W@2.8kHz
Effective cone area 8.5 cm2
V.C. diameter 28 mm
V.C. height -
Air gap height -
Lin. & max. excursion ±0.4/ ±1.5 mm
Air gap flux density -
BL 3.5 Tm
Moving mass incl. air 0.45 g
Net weight 0.7 kg
Outside diameter: 104.5mm
Cut out: 74mm
Depth: 41mm
25.4mm = 1" = 2.54cm
Midrange seas excel w12cy001 & Midbass seas excel w18ex001
Product information
Net weight : 4.6 kg
TECHNICAL DATA:
DC resistance 4.7 W
Power 225W@2.8kHz
V.C. diameter 28 mm
V.C. height -
Air gap height -
BL 3.5 Tm
Net weight 0.7 kg
Cut out: 74mm
Depth: 41mm
