- Joined
- Apr 11, 2006
- Messages
- 203
- Points
- 5,016
Compaq Presario V3165AU Notebook PC
HP Compaq Presario V3000 Reviews. Laptops Reviews by CNET.
Click da link above for Video & review.
http://i.i.com.com/cnwk.1d/sc/31864365-2-300-overview-1.gif
http://i.i.com.com/cnwk.1d/sc/31864365-2-300-front-2.gif
http://i.i.com.com/cnwk.1d/sc/31864365-2-300-sides-3.gif
http://i.i.com.com/cnwk.1d/sc/31864365-2-300-back-4.gif
used for < 1 year.
Selling for RM 1600
1.6GHz AMD Turion 64 X2 Dual Core
14.1"
Genuine Windows XP
80GB Sata HDD
512 DDR Ram
DVD CDRW Combo drive
1 battery
1 Adapter
Wifi
VGA out
Svideo out
Xpress Slot
USB 2.0
Built in Modem
Built in Lan 10/100
Processors Information:
Processor 1 (ID = 0)
Number of cores 2
Number of threads 2 (max 2)
Name AMD Turion 64 X2 Mobile TL-50
Codename Taylor
Specification AMD Turion(tm) 64 X2
Package Socket S1 (638)
CPUID F.8.2
Extended CPUID F.48
Brand ID 2
Core Stepping BH-F2
Technology 90 nm
Core Speed 1607.4 MHz (8.0 x 200.9 MHz)
HT Link speed 401.8 MHz
Stock frequency 1600 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 256 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 8.0x
VID range 1.075V - 1.150V
K8 Thermal sensor yes
K8 Revision ID 5.2
Chipset:
Northbridge NVIDIA GeForce 6150 rev. A2
Southbridge NVIDIA nForce 410/430 MCP rev. A3
Memory Type DDR2
Memory Size 512 MBytes
Memory Frequency 267.9 MHz (CPU/6)
CAS# 4.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 12
Bank Cycle Time (tRC) 17
Command Rate 1T
Memory SPD:
DIMM #1
General
Memory type DDR2
Manufacturer (ID) Hyundai Electronics (AD00000000000000)
Size 256 MBytes
Max bandwidth PC2-5300 (333 MHz)
Part number HYMP532S64BP6-Y5
Serial number 00007044
Attributes
Number of banks 1
Data width 64 bits
Correction None
EPP no
Timings table
Frequency (MHz) 200 266 333
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 5
RAS# Precharge 3 4 5
TRAS 9 12 15
TRC 12 16 20
DIMM #2
General
Memory type DDR2
Manufacturer (ID) Kingston (7F98000000000000)
Size 256 MBytes
Max bandwidth PC2-4300 (266 MHz)
Part number
Serial number BD2AD905
Attributes
Number of banks 1
Data width 64 bits
Correction None
EPP no
Timings table
Frequency (MHz) 200 266 266
CAS# 3.0 4.0 5.0
RAS# to CAS# delay 3 4 4
RAS# Precharge 3 4 4
TRAS 8 11 11
TRC 11 15 15
Call for more info : 014 877 66 11
No PMs pls.. rarely login.
used for < 1 year.
Selling for RM 1600
14.1"
Genuine Windows XP
80GB Sata HDD
512 DDR Ram
1 battery
1 Adapter
Wifi
VGA out
Svideo out
Xpress Slot
USB 2.0
Built in Modem
Built in Lan 10/100
Number of cores 2
Codename Taylor
CPUID F.8.2
Extended CPUID F.48
Brand ID 2
Core Stepping BH-F2
Technology 90 nm
FID/VID Control yes
max FID 8.0x
K8 Revision ID 5.2
Chipset:
Memory Type DDR2
CAS# 4.0
RAS# to CAS# 4
RAS# Precharge 4
Command Rate 1T
Memory SPD:
DIMM #1
General
Memory type DDR2
Size 256 MBytes
Attributes
Number of banks 1
Data width 64 bits
Correction None
EPP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 9 12 15
TRC 12 16 20
DIMM #2
General
Memory type DDR2
Size 256 MBytes
Part number
Attributes
Number of banks 1
Data width 64 bits
Correction None
EPP no
Timings table
CAS# 3.0 4.0 5.0
TRAS 8 11 11
TRC 11 15 15
