i have 1 16" rim without tyre...in drak grey/ honda grey...condition good...
with caps also ...very nice if got big disc brake...so can show off...
give me a pm...
if u want the tyre sure can.. still can use wan....
for ur info guys, the spoom rims which initially looks like 8 holes actually it is 4 holes only which is PCD100. the other 4 holes are like a design. i asked the tyre shop b4. it is not 8 holes or watsoever rims. and as for the weight it is impossible to be 5.1kg for a Spoon immitation. if im not mistaken it is around 6kg each rim. 5.1kg is considered a lightweight Japan rims oredi for eg: Enkei CPS-II.
i have a question to ask. why whenever i try to drive a large injector of low impedence (peak & hold type) via a resistor pack to a vehicle wid existing high impedence injector system i get this trouble of getting the car to idle on the 1st start. i have to wind down the fuel pressure till very low around 1.8bar in order to get started. starting up wid a low duty cycle couldnt help much wid stock fuel press as it seems doesnt response ... and once it ticks, i foul the plugs.
why ah..? can...
