Evo 8 MR FQ320
Evo 8 MR FQ320
Evo.8.MR
Johor Bahru
Engine & Performance
Tomei Cam Pulley
Tomei 260 Cams ( High Lift ) Exhaust & Intake
Sard Fuel Regulator
Walbro 255/l Fuel Pump
Hks LA Clutch (Brand New Used only 3 Months)
Re-flashed Ecu by Rom Tuning(Singapore Best Tuner) 385-bhp
Hks Hi Silent Full Turbo Back Exhaust System
Cusco Strut Bar with Brake Stopper
Full Custom Intercooler Pipes With Samco Hoses
Open Port Air INtake with Samco Hoses and Truss Airnix Filter
Ralli Art Radiator Hoses
Greddy Type R Blow Off Valve
HKS Actuator
Greedy Radiator Cap
Greedy Oil Cap
Full Motul Oil System for All Drivetrain, Excel & Gearbox.
Cusco Oil Catch Tank
Ralli Art Thermostat 71 degrees (so the car is always at 72 to 74 degree cooler then normal which is 82 to 84 degree)
Launch Controller
Chassis & Wheels
Volk Racing TE 37 17 inch 8.5J + 30 Offset (Perfect Evo Offset)
Greedy Type R 6 Way Fully Adjustable with Hi Lo, Soft Hard and Damper Rebound Rate all 32 Clicks.
Ralli Art Steel Braided Hoses
M7 Brake Pads 700 Degrees Front
Endless Brake Pads 1000 Degrees Rear (Carbon Ceramic)
Interior & Cockpit
Ralli Art 3 Din Oil Temp, Oil Press, Boost
Apexi AVCR Boost Controller
Apexi Turbo Timer & o2 Meter
Greedy Info Touch Meter 32 way MultiFunction
Pioneer Cd PLayer
Mohawk Full Component Speakers
Ralli Art Carbon Fibre Gear Console
Sparco Gear Knob (Limited Edition)
Exterior & Body
Pivot Full Grounding Cable
Monster Carbon Fibre Radiator Cooling Plate
EGR Head Lamp Protector
Billion Thermal Wrap for Exhaust System (Fully Wrapped From Turbo to Muffler)
Voltex Generator
Made 2004 Registered March 10 2009 and Mileage up to date only 43k.
Evo 8 MR FQ 320 6 Speed
The Car has 3 settings
-0.8 bar @ 260bhp
-1.2 bar @ 320bhp
-1.7 bar @ 385bhp
I have all the dyno chart for proof all the bhp.
+6596795899 (Mon-Fri)
+6012-7077374 (Sat-Sun)
Japan Spec bro.
---------- Post added at 03:50 PM ---------- 6 hour anti-bump limit - Previous post was at 03:48 PM ----------
bump car still up for sale.
if japan how can FQ?????
I could be wrong. Wikipedia also says that FQ is only for UK specs
# FQ-300 - Engine rated 300 PS (220 kW; 300 hp)
# FQ-330 - Engine rated 329 PS (242 kW; 324 hp)
# FQ-360 - Engine rated 359 PS (264 kW; 354 hp)
# FQ-400- Engine rated 410 PS (300 kW; 400 hp)
E8.MR,
Very nice set up you got there:top:
It doesnt matter if its a FQ-300, 320 or 340, they are just some marketting strategy in UK.
Based on your post, yours should be FQ-390 haha
Again, very nice
If i am wrong then Mutiara Motors also is wrong????
Japan have the FQ series but not the FQ 400.
Only uk has the FQ400.
The shipment cargo and also the tax payable forms are from japan bro so i cannot be wrong on this.
