Item : Evo 3 Front Antiroll bar & lower arm set
Price : RM480
Condition : Dismantled from halfcut
Description:
Item consist of Lower arm, antirol bar with linkage, mounting rubber & bracket. plug and play for wira, satria or putra. As antiroll bar is mounted on the absorber linkage mount bracket (telinga), thus your front absorbers must be equivalent to the GTi ones & the likes. The lower arm will offset your wheels approximately 10mm to the outside & 20mm to the front (if i'm not mistaken). This will increase ur front wheel track, wheel base & the best of all your wheel caster angle. Solid casted lower arm will reduces flex & deformation than the stock welded stamp press lower arm. Handling performance will be improved with the mentioned features.
Pics :
Item : Mivec Rear Antiroll bar & lower arm set
Price : RM280
Description:
Item consist of Lower arm, antirol bar with linkage, mounting rubber & bracket. Plug and play for wira, satria & putra. The antiroll bar (16mm) is thicker then stock wiras. Ball joint linkage will reduce the compression of rubber as on the "satay" stick linkage as on the stock wiras. A good upgrade for those with stock antiroll bar, best & most recommended upgrade for 1.3 & 1.5 that doesnt come with rear antiroll bar, recommended upgrade even before changing to sport spring or adjustables. Handling performance will be improved.
Pics :
Contact : Matt (018-2131320), Tajul (019-3341152)
Have plenty of sets in stock..
Price : RM480
Description:
Pics :
Price : RM280
Description:
Pics :
