Engine Setup for Drag and Track
aramis
Cyberjaya/KL/PJ
Can somone enlightened me about a good setup for drag and a good setup for track?
Many times and many people usually dump in many performance parts into the car without knowing what is it good for. Some parts are good for low-end, other, for top-end.
So, can some sifu enlighten me on this. Xenix, can help?
send ur car to Japan for Jun, sure ur car will get complete track/drag setup as u wish.
If you can spend like what Jin said.. Sending the engine to be engineer oversea.. then for track you can send to JUN/Spoon/TODA. as for drag you can send to Ericks Racing.
Aramis, If you wish to push the engine to the limit you got to choose either one. You can't have both setup in one engine.. Many things to looks into it.. If you wish to play track..
As for parts that benefits both setups are like changing the
.valve spring for safer high revving
.hi-cam for more intake and exhaust
.clucth set for more grip
.flywheel for better thorttle respone
actually many many more parts to be mention.
But the is certain parts that is not suitable for both setups like
.oil cooler only for track, as too cold engine doesn't benefit drag car
.four thorttle more for track, as drag engine normally doesn't rev too high while four thorttle power only comes in around 7~7.5k rpm. So if your drag engine is mean for only 8.5 rpm then it is no point putting in this parts
Many more to explain la.. hard to say it out in one time..
Xenix, very useful information. Please do post some stuff when u have time. thanks! ;)
to make it simple, lets say I want a drag car. What do I need/don't need?
no car is able to setup for both drag and track at the same time. you have to choose either one. like what ck has just mention, track setup requires
- chassis to be strengthen and lighten
- tweak ur chamber setting
- oil cooler
- no need change cams cause track requires mid range power
- good tires (slicks if possible)
- good engine management setup
- etc etc
What you really got in your mind right now..
Even the handling setup is different for Drag and Track. Hard to explain there la... If you wants we can tok when we meet.. susah la.. have to type type.. and some mechanical thermes I dunno how to give out the correct spelling.
somemore when u got a good drag machine, u need to practice launching, that one not easy
install a "Launch Control" / "Roll Control" like F1 can b done oso......
Launching is very easy.. Just attend BOBO launching School.
RM10 per session per 10 minutes. Estimated 5 launches. For BOBO fans club who have "I (Heart) 5050" sticker on the car.
RM25 per session per 10 minutes. Estimated 5 launches.
Jin, For your information F1 teams (those rich one la) like Ferari, McL.. The pilot doesn't launch the car. It is the Enginer team that launch the car from the computer control room. And the ECU the are running is a 2 way comunication system which means they can change and configure the setting withount touching the race car. All in the computer room. FIA tried to ban this but they found out it is nothing they can really do.. As IT people should know that they can just simply can the transmitting code and signal and FIA will never able to find out. And the Pilot only takes control after the car is lunch by the team enginer.
And for WRC the pilot is the one who launch the car.. If you watch WRC you will see them releasing the hand brakes during launch.
< For BOBO fans club who have "I (Heart) 5050" sticker on the car.>
how bout "i have BOBO's Seat in my Car"...ehehehehe
no ler. Im not asking for a car for bothe track and drag.
What I need to know is what is needed for a track car and what is needed for a drag car.
Originally posted by zero4@Nov 10 2004, 14:45
hahahahahahahahahahahahahhahaha
u forgotten to mention entry fee is 500 bucks CASH lah ck
No la.. that is the price he is charging la.. Ask him and see.. Hahahahaha
Aramis, I'll try......
For drag : With budget constraint as a factor, I would strip and lighten my car as much as possible. So all other irrelevant things that can be cut or taken out, do it. And even to the point of lightening myself :lol: :D Increase power at high rpm (rather than peak power at a lower rpm), which can be done by an EMS, or changing of extractor to 4-1. Low tyre pressure in front, with wider tyres + rims in front, and vice versa at the back. Suspension set up front soft, rear hard. Front camber as zero as can be. U also need quick gearchanges. Last but not least, use higher octane fuel, aircraft fuel if you've got any pilot frens. ;)
For track : With lightening of the car, there must also be chassis strenghtening, i.e. anti roll bars, strut bars, roll cage, and whatever other bars u can think of - for handling and your own safety. Harness + bucket seat. A good set of tyres, pref. semi slicks. A good alignment job. Front shud hv more camber than rear. A good brand of coolant. A cold air intake. New engine fluids, i.e. gb, engine, brakes, clutch, power steering etc. Engine shud not rev higher than 8k rpm, if u love ur car. Easy on the gearchanges, i.e. do not change gears as if u stole the car.
My 2 sen. But I'd like to merge both of the above ;) most of the time.
if got money, of coz can merge both of them, can always take things out and install and retune mah
i luv my car but i still rev above 9k wohhhhhhhhhhhhhhhh, ahahahhahaha
Originally posted by KillerB+Nov 10 2004, 15:19 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (KillerB @ Nov 10 2004, 15:19 )</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-aramis@Nov 10 2004, 14:06
My 2 sen. But I'd like to merge both of the above ;) most of the time. [/b][/quote]
For Drag,
If the car is lighten to the max you need a roll cage to strengthen the chassic or else the car won't be able to go straight. The lightest parts of the chassis to be best is the rear side of the chassis.. The rest of the point is ok. If you need extra explaination on it. you can ask me. Hehehe
You can never merge both is you really want to push it to the LIMIT. cause like the piston bore. you bore it to 86mm and you can never mend it back to 85mm..
If you that rich... but a track car la.. don't cause you too much.. about 3~5k depends on model. so you got track and drag car lo.. less hassle.. save your workmanship somemore.. if you are going to do like zero4, take out and put in and re-tune...
woh... mucho information... thanks KillerB and Xenix.
Drag, Rear bumber must be moddifed to allow air flow so that it won't hold back the air pressure.
Explaination, You try to ride on a bike while holding a payung or baldi. You fell the pressure that holds you back ride.. that is the same thing happening to your rear bumper. This is more on aerodynamic modification.
