EK9 brake rotor size
J101
1,304
malaysia
i did a search in zth
found some words by chris2000
"EG B16A/EK B16A/DC2 GSR All 262mm diameter disc with 4 hole PCD 100
DC2 96 spec Type R 262mm diameter disc with 4 hole PCD 114.3
EK9-R / DC2 98 spec R 282mm diameter disc with 5 hole PCD 114.3
Prelude BB1 282mm diameter disc with 4 hole PCD 114.3"
kikaider
249
I am asking this because i wanna get a set of Wilwoods but someone posted that its only a 240mm disc. So i want to know whether Wilwood kits use smaller discs or are they for the rear. Its a Dynalite 4 pot with 240mm 2 piece rotor/aluminium hat. Also if i were to redrill the hat to fit my car will it weaken the structure?
shiroitenshi
3,676
170
Well.. I'm NOT familiar with wilwoods, but the some sets I saw came with brackets. And the accompanying discs are BIGGER than the EK9..
So can't really help you there.
As for drilling the center lug holes, yes, they do weaken the structure, as with everything else that gets a hole punched in them.. :P
But what holds the discs in place during hard braking is not those two tiny screws, but your wheel hub area and the lugs, which is why high horsepower cars/trucks tend to have more lugs.. 5 for cars, 6 for trucks, and up to 8 for lorries.. (O_o)
kikaider
249
I just got things cleared up, the dude actually posted wrongly...its actually at 300mm disc. Will ask my mech bout the reliability of drilling the 4x114.3 holes on the hat. Cause at the moment the disc either comes in 4x100 or 5x114.3.
kikaider
249
Another thing which is out of this topic....those driving EK, are the 2 bolts on the rear of the front seats different size? I am trying to find eye bolts to hook on my sabelts...anyone know where i can get them?? I want good quality ones, dont want to snap incase of anything.
shiroitenshi
3,676
170
Well.. I guess that my estimations on the disc size true then, because wilwood are usually bigger than stock, and require 16" rims. I just looked at it, but never thought buying... I sort of like 15" and ek9 brakes.. they're just nice..
Now if only I'm willing to spend on a good set of VR TE37s.. :P
kikaider
249
Actually anyone using a big brake kit for the fronts on their EK? Would like to know how it feels like. Also where are the replies on the eye bolts for the harnesses?
shiroitenshi
3,676
170
Eye bolt harnesses.. that one you have to ask track kakis.
I'm using an EK9 brake kit on my EG.. consider a big brake setup or not? (O_o)
JINEIL2EN
15,317
525
Island Of Pearl
team99ers.2.forumer.com
any1 wants the EK9 Front Caliper Sets with 4 X 114.3/100 size 282mm disk rotor?? Come with Project-u 0-550'c HD-Kai Brake Pad which used for bout 1 month...
Price can be nego...pls PM me for more details...
Johnny_9
278
a) 262mm discs + 8.2lb Regamaster Rims
b) 282mm dsics + 9.2lb TE37 Rims
=> which will give better braking performance?
kikaider
249
I just bought myself the Wilwood Dynalite Brake Kit 4 pot. Cant wait to fit it on to my EK.
kikaider
249
They are brand new, paid less than RM4k. Yes, the rotors are 2 piece. Will take some photos this Friday.
shiroitenshi
3,676
170
Good.. The dynalites lookes really nice in catalogues.. and less than 4K? Wow.. that's a good price.
At least loads cheaper than AP Racing or Spoon.. (O_o)
J101
1,304
malaysia
i think theres more to it than just having monster brakes and calipers.
1. what master brake cylinder size are you using? AP Racing Master Cylinder?...etc
2. what brake fluid are you using? Dot 4?....etc
3. are you using any adjustable hydraulic brake proportioning valves to support this upgrade? Tilton?...etc
Tyres do play an important role when it comes to braking. So overall its quite subjective when it comes to best braking performance combination.
kikaider
249
I bought it off a forumer. He hand carried it all the way back from the US. Over here can get Wilwood from Pentagon. The only drawback bout the kit is that have to use back Wilwood brake pads. I better go buy another set to keep. Anyone here knows the differences in Wilwood brake pads? Like from the highest to lowest temp.
Hi.
i was wondering.. theres so many types of grounding kit in the market.
Seller told me the thicker the better. But since im drving small kars.. like satria and kelisa. Wouldnt the thick grounding wires too much for the car to handle?
thanks.
