DLS,Kicker,Orion,Kenwood,Critical Mass & Autobahn
ICE -In Car Entertainment
cwaii
New Items For Sale
DLS
DLS Ultimate A Series Amp
A7 5Channels Amplifier (RM4,700.00)
(ITEM SOLD)
ULTIMATE series A7 Five-channel amplifier rated at 4 x 60 Watts on the stereo channels plus 1 x 300 Watts from the mono sub channel.
Built to provide a complete in car entertainment system system with all necessary crossovers, all in one amplifier. For detailed information about the crossover possibilities please read the technical specifications.
Internal switches connects all amplifier inputs if you prefer to use only one RCA cable.
Built-in fan control. Remote sub level control with phase shift is included.
RMS output per channel at 13,8 volts, 20 Hz - 20 kHz , < 0,1% distortion.
Mode : AB
Number of channels : 5
Output power in 4 ohm : 4 x 60 W
The stereo channels can be connected in bridge mode giving a power of 2 x 200 W RMS
Output power in 2 ohm : 4 x 100 W
Mono channel, output power in 4 ohm : 300 W
Mono channel, output power in 2 ohm : 440 W
Mono channel, output power in 1 ohm : 600 W
S / N ratio, A-weighted : > 100 dB
Damping factor : > 200
Input impedance : > 10 kohm
Input sensitivity, variable : 0,3 - 7 V
Filter ch. 1 & 2 : Highpass: 80 - 400 Hz / 1,6 - 8 kHz (x20)
Filter ch. 3 & 4 : Highpass: 80 - 400 Hz. Lowpass 0,3 - 4 kHz / 3 - 40 kHz (x10)
Filters mono sub channel : Lowpass: 50-125 Hz.
Terminal for external cooling fan : Yes
Phase control : 0-180 degrees continuously
Remote sub level control with phase shift : Yes
Dual DC-inputs : No
Current draw, idle : 1,1 A
Current draw, maximum : 120 A
Dimensions W x D x H : 605 x 240 x 73 mm (23,82 x 9,45 x 2,87 inch)
Weight : 8,1 kg ( 17,86 lb)
Pictures
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0160.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0161.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0163.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0164.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0165.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0173.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0175.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0176.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0178.jpg
DLS Ultimate Series Component Set
UR6S 2-ways Component System (RM2,300.00)
(ITEM SOLD)
Ultimate series UR6s is a 16,5 cm (6,5") 2-way system. The 6,5" driver uses a unique sandwich cone built of three layers like a honeycomb. Hybrid ferrite/neodymium magnet system. New model 2006 with die cast basket. Three inch voice coil. Filterboxes with selectable tweeter level. 28 mm silk dome tweeter UR1. Grilles are included.
Speaker type : 2-way system
Woofer size : 16,5 cm (6,5")
Power handling capacity : 100 W RMS / 160 W max
Tweeter : 28 mm (1,1") tweeter
Sensitivity : 91 dB (1W/1m)
Magnet size : 85 mm (3,35") Hybrid ferrite/neodymium
Outer diameter of woofer : 165 mm (6,5")
Installation depth : 65 mm ( 2,56")
Mounting hole : 140 mm (5,51")
Crossover : Box filter LP: 6 dB & HP: 12 dB slope
Pictures
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0145.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0146.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0148.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0150.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0152.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0156.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0157.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0158.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0159.jpg
Important Information About Fake DLS Products
http://www.dls.se/english/
Kicker Products
Kicker KX650.4 4Channels Amplifier (RM2,200.00)
KICKER amplifiers have always ruled the winner's circle at car audio competitions because they combine remarkably advanced design features with the highest-grade electronic components and manufacturing tolerances for the ultimate combination of sound quality and brute power. The new KX series stereo amplifiers feature outrageous removable amp shrouds that scream “power.” Beneath the exciting exterior lies fan-cooled internals that have been designed from the ground up to deliver tight, clean power. An unregulated Class A/B power supply allows the amplifier to really pour on the power in 2-ohm operation. All this power is at your command with continuously variable crossovers, high- and low-level inputs, and variable bass boost. Fast-acting protection circuitry guards against short-circuits, over-voltage, overheating, or wiring mishaps. Gold-plated RCA input connectors insure maximum conductivity and resistance to corrosion. High 22kOhm input impedance lets you link multiple amplifiers in a single signal chain without having to use signal-robbing splitters. Custom-tooled remote and speaker screw terminals are also gold-plated, while oversized power and ground terminals allow positive connection for up to 4 gauge wire. Dialing up just the right amount of bass is at your fingertips with the KickBass variable bass boost. KICKER even ships every amp with its own birth certificate – KICKER's guarantee to you that it meets their high standards for power and performance.
Features:
• Radically Advanced Chassis with Removable Chassis Shroud
• Fan Cooled
• Short Circuit, Over-Voltage, Reverse Polarity, Thermal (SORT) Protection
• MOSFET Power Supply
• KickBass 0-18 dB Variable Bass Boost at 40 Hz
• Included Remote KickBass Control
• 12 dB / Octave High- or Low-Pass Crossover
• Variable Crossover Frequency from 50-200 Hz
• Delayed Turn-Off Logic Circuit
• Soft Start Turn-On Circuit for Reduced Startup Load
• Removable EndKaps Cover All Connections
Multi-Channel Amp Specifications
• Amplifier Type: Multi-Channel
• RMS Power @ 4 Ohms: 120W x 4 @ 14.4V
• THD at 4-Ohm RMS Power: • Bridged RMS Power @ 4 Ohms: 325W x 2 @ 14.4V
• Speaker Level Inputs: yes
• Preamp Outputs: no
• Built-In Crossovers: HP/LP
• Bass Boost: 0 - 18 dB
• Frequency Response: 20-20,000 Hz
• Signal to Noise Ratio: >95 dB
• Fuse Rating: 2 x 40 amps
Pictures
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0198.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0199.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0200.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0204.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0205.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0207.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0208.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0210.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0212.jpg
Kicker K65.2 Component Set (RM700.00)
Key Features:
1" titanium dome tweeter
6-3/4" polygraphite woofer with titanium-deposit coating
treated foam surround
2-way 4,500 Hz crossover network (12 dB/octave high- and low-pass)
frequency response 33-21,000 Hz
recommended power range 6-75 watts RMS
peak power handling 150 watts
sensitivity 88 dB
top-mount depth 2-1/8"
Pictures
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0187.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0188.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0190.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0191.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0192.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0193.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0194.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0195.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0196.jpg
Kicker X3I-2 Electronic Cross-Over (RM480.00)
variable low pass and two variable high pass filters.
Remote control bass boost is variable to +18dB at 40Hz. Also features 24dB/octave subsonic filter, two stereo inputs, and three stereo outputs
Front and Rear High Pass Crossovers - 18dB/octave, Variable Frequency (35-400Hz, 20x Multiplier Option on Front Crossover)
Sub Low Pass Crossover - 18dB/octave, Variable Frequency (45-250Hz) Bass Boost Variable to +18dB at 40Hz Remote Level Controller 24dB/octave Subsonic Filter Two Stereo Inputs with Parallel Input Option Three Stereo Outputs (5V rms) Signal-to-Noise Ratio - +100dB
Pictures
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0183.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0184.jpg
Used Items (Still Inside My Car)
Tip Top Condition For All The Items.
Kenwood 12 Excelon Dual Voice Coils Subwoofer with Enclosure (RM380.00)
Specification
http://www.kenwood-electronics.com.my/cms/General.asp?whichfile=Subwoofers&ProductID=332&CatID=
Pictures
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0220.jpg
Orion HCCA 250GS Amp (RM1,550.00)
Pictures
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0223.jpg
Critical Mass EQ30 (RM850.00)
Pictures
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0221.jpg
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0226.jpg
Autobahn 3-ways Electronics Cross-Over (RM320.00)
Pictures
http://i35.photobucket.com/albums/d199/cwaiii/CIMG0222.jpg
For those who are interested,please email me [email protected] or call me 6019-3849344,my name Choong Wai.
Thank you.
Monday morning bump....
Update!!
Orion HCCA 250 G5 Booked.
