DIY fix boot leakage.
JasperSSP
131
To all wira owners, anyone fixed their boot leakage problem? I have already siliconed both the rear lights but water is still going in, and lately more serious. Where is the correct spot to seal?
Regards.
evo5755
332
just drill a hole to the affected place..or release a button underneath which is near to your fuel tank....U cant really fix wira actually... ;)
DarkAccoon
880
432
3,063
i already fixed it lorrr
here are the problem areas
DarkAccoon
880
432
3,063
notice the difference between the two photos i am going to post, now be smart and look properly
then seal up the hole only larr
just some welding error from proton
DarkAccoon
880
432
3,063
here is what it's suppose to be
DarkAccoon
880
432
3,063
aiyak....
the quality of picture not really that bad larr
the difference is
notice there is a gap between the two metal plates in the first picture
whereas the second picture is a small gap
just use some silicone glue to fill it up
kau tim, no more water
wfhan,
where is the QC in proton you ask
i answer, IN THE BOOT
badguy
951
that is also possible leakage from the tail light!!!
check it out
last time my leakage is from there
JasperSSP
131
badguy, I've already sealled off the lamps. I took out the rubber and seal of this part cause it's not properly soldered together. Guess what I found, proton has already sealed it off using SILICON. but it did not cover properly, so I put more, DarkAccoon, thanks for sharing, that's the exact spot where my boot is leaking. will check when I'm free. thanks
DarkAccoon
880
432
3,063
you used silicone to seal the rubber and the metal plates???
what type of silicone did you use?
if normal silicone, then die rite cause after it dries you cannot take it out wert???
anyone knows what type of silicone is used and where to get it arr
JasperSSP
131
darkaccoon, I just use the normal silicon. bought from hardware shop, the clear ones. anyway, I just took out the rubber to check, just pull and it came off, the silicon doesn't stick that much. There is a hole like where you mentioned, but only very small and the other side which is not leaking has a even bigger hole. Anyway, just sealed off both, will notify you guys the next time it rains, or when I wash my car.
regards.
DarkAccoon
880
432
3,063
jasper,
if you use the normal silicon rite.....
when it dry up then you cannot pull the rubber thingy out anymore wor?
DarkAccoon
880
432
3,063
what about the rubber sealant between the door
I
Indecided
Guest
rubber sealant between the door?
no, no... those are rubber mouldings AFAIK..
sillicone should serve its purpose here, another spot commonly missed is the power antenna hose, the rear light seals (yep, u can replace them...)
wfhan
4,339
96
selangor
Originally posted by DarkAccoon@Aug 16 2004, 11:54 AM
wfhan,
ah ... hahahahaha... :lol: :lol: :lol:
maybe not only the QC fella in the boot,
the whole R&D and technician that pasang
the car oso IN THE BOOT ler.. hahahahahhaha.......
A Post Every 5 Mins
hi have any 1 of you try among these 2 type of engine?
then if yes then do you guys know which engine will win in pick up and top speed?
if a gsr wira VS a gsr CK 4wd, which car will faster?
have u guys try b4?
thanks..
