Different offset???
U go very slow maa ... coz cannot clear the speed bumps in KL .. :rofl::rofl:
But the actual reason is u probably using the same specs of tyres ... which i still don't understand why the thread starter still don't get it ...:banghead::banghead:
Woi...I got it la...just want to know others set up mah...I'm going for
18X9 offset +25 Front
18x9 offset +35 Rear
Tyre same spec...255/35 R18...
my E7 using
F 17X7 +35(225 45 17)
R 17X8 +40(225 45 17)
any suggestion to me??
I also dunno la...but as my personal opinion it's better to have the rims same size...what i mean same size is diameter and width MUST same...different offset it's ok...and same size tyres is mandatory...the reason why? according to pablo's explaination about Newton's law...so logically all 4 tyres + Rims MUST have same weight...
Hail to the Prof. Pablo...!!!:adore::adore::adore:
Wen : I thought the max rims offset for an EVO is +38...How come yours is + 40..???:hmmmm:
i am running on 2 different offset, so far no problem.
Towkay.......ur car park at home aja sure lah. bring jalan jalan like evening walk. Bring to sepang 5 lap 2 or 3 times then u let me know got problem or not :rofl::rofl:
---------- Post added at 11:37 PM ---------- Previous post was at 11:36 PM ----------
the +40 offset can fit rear not front
my tyre all same size la. bro :rofl:
I think it should be no problem...Since the ORI E7 rims is 7.5J...If I'm not mistaken laaa....:hmmmm::hmmmm:
Is 8.5jj la
so i wonder 8jj can fit to it or not E7
I got ask those selling rim guy he said 8jj cant suit???
still confuse about it? Any idea....:confused:
Is 8.5jj la
Which specs of E7 is using 8.5J as standard rims...??? My previous SA 70 rims is 8.0J..No problem with it...The important point to check when buyin' a rim is the offset...Cause it will determined whether it can clear the BREMBO caliper or not...8.5j with +42 offset will definitely can't fit in EVO as 8.0J with +32 offset do..:driver::driver:
thank let me know about it cox not familiar with those offset +42, +32....
that means offset +32 or lover it can fit la?
Hi Guys
Here is some Usefull Info to help you Clarify your Wheel Issue , As your Wheels and Tyres are Essentially the Most Crucial Aspect of your Car , It is Essential to have one that Compliments the Tolerances Laid Down by the Manufacturer
The wheel offset is the distance from the hub mounting surface to the centerline of the wheel. The Offset diagram 1 shows a positive offset in which the mounting surface is outside of the wheel centreline. This suspension/ wheel combination was chosen to maximize performance. You can see that the suspension geometry intersects the centreline at the road surface for optimal handling.
If you select an aftermarket wheel with the exact same offset, you will always have the exact same scrub radius. Suspension and handling properties will not change.
If the new wheel is wider than the stock wheel, you will loose clearance on both suspension and wheel well sides. There is obviously a limit to how much of a width change you can make.
Often a driver will select a wheel with a smaller offset than stock. The attachment Offset diagram Zero Offset shows a zero offset where the mounting surface is equal to the wheel centre. (You could go even farther and select a wheel with a negative offset.)
A smaller offset will create a scrub radius which may affect the handling of the car, but there are a number of reasons why you may need to choose a smaller offset.
1. To compensate for a wider wheel: A wider wheel with the exact same scrub radius as the stock wheel will be positioned closer to the suspension components. If the wheel is too much wider, it will not fit. To compensate, you would choose a smaller offset to move the wheel away from the suspension.
2. To create a wider stance: By setting the wheels outward, the stance of the car becomes wider and stability is increased. In some applications, the benefits of this stability are greater than the drawbacks of the scrub radius change and the driver may make this compromise.
3. Looks: A smaller offset moves the wheels outward, so they have a tendency to fill out the wheel well better. Cars set up for show, more than performance will often choose a lower offset wheel, however, if the offset is too small the sidewall will rub the inside of the fender.
Hope This Helps
my experience we were try in brunei is...
Work Crkai 18x8.5 offset 30 - 235/40/18
i see in states using 18x8.5 offset 20 (coz its more hav concave offset) - 235/40/18
Advan RG,RS,RZ 18x8.5 offset 31 - 235/40/18
18x9 offset 29(GTR face) - 245/40/18
SSR Type-F 18x9 offset 32 - 245/40/18
all this offset will fit into ur original stock fender and clear all the brembo's..............
my 2cent experience.........
