DD RACING 6 POT BRAKE CALIPER KIT
*SAFETY START WITH DD*
Heavy duty stainless steel pistons reduce heat
transfer.
DISC ROTOR 380MM,356MM ,330MM,303MM,285MM.
PACKAGE CONTAIN : CALIPER 6POT x 2PCS
DISC ROTOR 330MM x 2PCS
ADAPTER x2 PCS
BRAKE PADS 1SET "550DEG"
MATERIAL : FORGED aluminum alloy
YOU ARE BIDDING ON A COMPLETE FRONT BRAKE KIT FROM
DD///.
EACH KIT CONTAINS A MATCHED SET OF CALIPERS AND
ROTORS SPECIFICALLY DESIGNED FOR EACH APPLICATION.
INSTALLING LARGER BRAKES WILL DECREASE YOUR
STOPPING DISTANCE, PROLONG THE LIFE OF THE PADS
AND ROTORS AND FILL UP THE SPACE BETWEEN THE
CALIPER/ROTOR AND BARREL OF WHEEL
D&D PERFORMANCE
near sunway lagoon,area kakimotor n1 racing
samurai racing ken racing jc racing
rev , works engineering...DND
POWER
email:[email protected]
[email protected]
hp: 6016-3328 136 / name : seng
transfer.
ADAPTER x2 PCS
DD///.
D&D PERFORMANCE
POWER
[email protected]
