http://s27.postimg.org/cpqlumhsj/20141016_232349.jpg
http://postimg.org/image/axb4mdwgf/
http://postimg.org/image/iav3z35vz/
http://postimg.org/image/xaiv96xe7/
CONTINUOUS OUTPUT NOMINAL POWER*:
[both ch. driven from 20 hz to 20 Khz; THD < 0.1%]]
2x 50Watt/4ohm @10.5 Vbatt.
2x 100Watt/2ohm @11.5 Vbatt.
1x 200W/4ohm (bridged) @11.5 Vbatt.
OUTPUT CURRENT [THD 12 Arms continous
20 Arms (500mS peak)
FREQUENCY RESPONSE[-3Db]:
at 8 hz and more than
400 Khz (at nominal power into 4 ohm)
THD:
less than 0.1 % until 1° clipping [20 hz to 20 Khz]
INPUT IMPEDANCE:
10 Kohm
INPUT SENSITIVITY: max 300 mVrms; min 4 V rms
STEREO SEPARATION: 80 Db at 1 Khz
SIGNAL TO NOISE RATIO: >120 Db "A" weighted
CURRENT CONSUMPTION [at 12 Vbatt]:
- idle= 1.2A
- 17 A max at nominal power into 4 ohm (stereo)
- 34 A max at nominal power into 2 ohm (stereo)
- 34 A max at nominal power into 4 ohm (bridged)
PROTECTION TRIGGER AT:
- short on speakers outputs
- battery voltage < 9 V
- battery voltage > 15 V
- thermal with proportional start of fans at 40° C, shutdown at 70° C
- fully muted at turn on and off
DIMENSIONS AND WEIGHTS:
237 x 295 x 66 mm
4.5 Kg
all item new in box, old stock. interest pls pm
THD:
INPUT IMPEDANCE:
10 Kohm
- idle= 1.2A
237 x 295 x 66 mm
4.5 Kg
