lake315: Can't say what's really wrong with your car. If its the engine mounts then the only way to diagnose it is to look at the mounts or try grabbing your engine when its off and rock it back and forth and see if it moves a lot or not.
lake315 said:it's the mounting. not at a very bad stage but going there. that somehow cause the noise. the engine mount can't hold the engine like the way it should, and when lotsa electricity being used i.e. air-con, headlamps and such, the engine vibrate, which cause the noise.
another possibility is the alternator. maybe the bearing /or there is something wrong with the bearing.
they have yet to check.
guys, is this true? i don't really agree on the second reason.
lake315 said:bro(s),
the info(s) that i supply you, incorrect. Here is the scenario,
i start my car, it revs up to 2000 rpm, then fall backs to 1000 rpm, stays there for a minute then it falls to 900 rpm. I don't have problem with that. Then i turn on my headlamps, so it starts, it falls down to 800 rpm and every freaking thing starts to vibrate (the most iritating one is my side door window, due to bad workmanship when i install a new sets of speakers). When in idle, i rev to 900 rpm to 1000 rpm, nothing vibrates, but when it falls back to 800 rpm, it vibrates. Then, it'll go up to 900 rpm (no vibration), falls back to 800 rpm (vibrate), during both time, idle and change of gears. Up and down during idle. Is this a common thing? should i not worry or should i do something? a re-tune? or fixing the voltage stabilizer? the mountings? what can effect the tear of the mountings? i'm not a hardcore driver fyi and the car is only 5 1/2 years old.
thanx a million guys.
