khellvinne
Just assume you can have 50% extra power. (By rule of thumb)btw..i hav one question..
if i install this turbo kit on cps neo vs. non-cps neo...mesti ade sikit difference in hp kan?kalau assuming everything else is the same la..i'll assume the cps neo will hav a slight advantage in hp later on, kan?thnx in advance..
Hi kk9972..
The price i quoted here is of course without management. But as u know, u would have to buy and install the management system at a different cost. The management system that we recommend for u to use would be either Haltech Interceptor or E-Manage. Both are piggyback ECUs
I plan to install better cam shaft and change the ECU before go for your turbo.
Is it then I no need to add or change ECU already since I already have a piggy back?
