- Joined
- Feb 21, 2006
- Messages
- 7,969
- Points
- 1,638
modified turbo built to fit B6T, has larger compressor wheel and bigger compressor housing, hi-flowed exhaust housing, oversized wastegate port with larger flap, recently reconditiond, has only done 500kms max on my rally car, is in mint condition with no end play, comes complete with dump pipe and water pipes etc
this turbo would be a great upgrade for a road car, is designed to flow well and be reliable at high boost, it was running 14psi and has minimal lag and pulls hard to redline!
does not come with manifold pictured..
the number stamped onto the cover as the turbo spec is not relivent as its been modified to fit the larger compressor wheel which i think is off a vf8 or vf10 subaru turbo, this allows alot more flow and supports higher boost without overspeeding the shaft and bearings, the centre and exhaust side are standard bfmr which i think is vj20 and has the mods as detailed above, hope this helps, thanks
OFFER ME A PRICE
Selling in behalf
THIS HAS BEEN LISTED ELSE WHERE,ITEM WILL NOT LAST..
[email protected]
OFFER ME A PRICE
Selling in behalf
[email protected]
confused.. Well, it goes like this..
