How much boost can b8 bpt/bpd stand before explode?
Aku baru Beli kereta lantis dah dapat spec cam ni :
B8 180 conrod piston JE forged piston
Management haltech
550 injectors
Turbo gt35
Mintak tlg kawan2 bagi pendapat
Ingat hari sabtu ni nak p dyno
Tak tahu lak nak up boost berapa?:confused:
fuhhh haltech. JE piston...
skrg standard boost brape??
boleh start from 1 bar...
i've seen 180 engine with 210 turbo producing 300+ hp. to me, its not the boost that we should concern, it is knock that destroy the engine
boost cut cant b removed but u can bypass it...cheap solution is getting a safc or any other piggy back computers...
HEy all..
Would like to know wat is the cheapest way to remove boost and speed cut for a B6T ?
CHeers to all..
hey all..
Would like to know wat is the cheapest way to remove boost and speed cut for a b6t ?
Cheers to all..
how much cheapest way u want??
If easiest way u can bought used safc lorr.....
i think safc, fuel regulator, walbro, vr4 injectors metal gasket can boost higher already......just put a td05 and boost 1.5bar and see the B6T fly or use VJ23
it seem it you pics there like Lantis engine in an astinaYou did BOT ke?What's your BOT specs?
