Apexi AVC-R Used For Sale!!Repost
zackdiablo
Nilai
Used AVC-R for SALE
The AVC-R is a digital boost controller that allows the user to modify the boost pressure level on turbocharged vehicles. While there are many boost controllers on the market, none of the other includes as many features as the AVC-R, period. Despite all of the complex features included the unit, the AVC-R is flexible enough to be used by beginners. Entry level users need only to input a desired boost level and the AVC-R's trademark self learning CPU processor does the rest.
The AVC-R also uses a highly durable, fast action solenoid valve to physically control the boost . The valve movement (Boost Duty Cycle) can also be modified. Raising the duty cycle increases boost response, while lowering the duty cycle will slow boost response. This feature allows boost response adjustment for varying turbo sizes. Since larger turbos take longer to spool up ( bad low end response) the duty cycle should be raised under lower RPM's for better response. The opposite should be done for smaller turbo's ( excellent low - mid range response, but limited top end power.) A'PEXi engineers address this issue by including extra menus for RPM based boost control. Drag racers may want to utilize the Gear based boost control function. Aside from the basic functions above, the AVC-R has a Start Duty Setting (allows the boost to momentarily overshoot according to gear).
The AVC-R also includes a Scramble Boost function which allows the user to momentarily raise or lower the boost level at the push of a button. Raising the boost level is commonly used when an extra burst of power is needed (ex. entering a freeway). This feature can also be used in drag racing. The driver can set the main boost level to a low setting for maximum traction then, once full traction is achieved, the scramble boost can allow the vehicle to boost full power.
The AVC-R displays data in three different modes: Numerical, Analog, and Graph. Numerical Mode allows the user to monitor up to four different parameters in numbers and also shows peak hold values on demand. The Analog Mode displays up to two values in an easy to read meter style display. Peak Hold is also included in this function. The Graph Mode offers real time graph plotting with a Ghost map trace feature built in. The graph can replay movement up to 60 seconds.
CONCEPT:
Advanced electronic boost controller
CHARACTERISTICS:
Highly flexible boost control with new functions
NO SMS
Call 016 2186009
Price???? RM 1299.99 NEGO
How Long I Used it??? 3 Months (July 2005-purchased)
can it be install in mazda B6 turbo.
sorry newbie here
is yours the black casing version retailing for 1700?
sorry, bro......cannot,
and u seem not a genuine buyer, coz a genuine buyer will call me directly...
izzit enuf to supply fuel when raises boost w/o put f/regulator or safc??
Avcr
Hi,
Have you still got this for sale? If you do I am intereted but will only be in Malaysia on 5th of January. If you have it I am willing to meet up and pay you RM$1200 for it cash. I am coming from Indonesia and am willing to pay you up front cash. Thanks. Please get back to me. Please... I want this so bad. My friend introduce me to this website as he lives in Malaysia. Thank you.
regards
Hairy
damn... i always wanted one =(
free bump for u!! =)
