- Joined
- Nov 16, 2004
- Messages
- 253
- Points
- 3,016
1) kicker ZR360 to let go
used bout 2 years
in very good condition
a very good old school amp
stable to load at 2 ohm
for those who like to play spl or those using double voice coil sub,this amp suit nicely
specification from review
http://www.carsound.com/review_archive/amps/zr360.html
All measurements @ 14volts unless otherwise specified
Frequency Response (4-ohm IHF Load, 20 Hz to 20 kHz 1 kHz Ref.): +0 dB, –.8 dB
L/R channel error max deviation 20 Hz to 20 kHz: .03 dB
Phase Response (4-ohm IHF Load, 20 Hz to 20 kHz 1 kHz Ref.): +20 degrees, –43.8 degrees
Signal-to-Noise Ratio (Below Rated Output, “A” weighted): –103 dB
Distortion at Rated Output @ 1 kHz: .034% @ 400 watts
Output Power (resistive) minimum output
(20 Hz to 20 kHz @ 1% THD+N, all channels driven into 4 ohms)
: 141.3 watts x 2 @ 14 volts
; 141.1 watts x 2 @ 12.8 volts
; 107.4 watts x 2 @ 10.4 volts
(20 Hz to 20 kHz @ 1% THD+N, all channels driven into 2 ohms)
: 257.4 watts x 2 @ 14 volts
; 244.5 watts x 2 @ 12.8 volts
; 167.5 watts x 2 @ 10.5 volts
Output Power (4-ohm IHF Reactive Load @ 1% THD+N @ 60 Hz bridged): 574.2 watts
Output Power (2-ohm IHF Reactive Load @ 1% THD+N @ 60 Hz bridged): 725.4 watts
Crosstalk (Referenced to Rated Output, 20 Hz to 20 kHz): –62.4 dB
Damping Factor @ 100 Hz: 147
Voltage for Rated Output: 102 mV to 2.14 volts
Idle Current Draw: 2.3 amps
Current Draw @ 1/3 Maximum Power: 37.6 amps @ 182 watts
Efficiency @ 1/3 Maximum Power: 35%
Power-Up Noise: 10.9 dB SPL
Power-Down Noise: 11.3 dB SPL
original spec on manual
can check from website given : - http://www.kicker.com/05/techsupport/manuals/manuals/ZRAmpsMan.pdf
sold
2)1 pc of used MTX 6500D for sale
Power 12.5 VDCInput
[font=Arial,]2 Ohm Load500 w x 1
4 Ohm Load250 w x 1
Power 14.4 VDC
2 Ohm Load775 w x 1
4 Ohm Load450 w x 1 [/font]
11.5" x 9.75" x 2.1"(29.2cm x 24.8cm x 5.3cm)
http://www.mtxaudio.com/caraudio/archive/images/ampT6500d_400.jpg
just did survey
brand new price bout 2.8k
thats for replacement model of this
which is thunder 801D
spec all the same just out look a bit diff
just used for 1 year plus
free RCA + power cable + fuse box
not those pasar road RCA
selling at RM888
come fast fast
3)clarion DXZ746MP (used bout 2-3 months)
- used for 2-3 months
- selling price is 1.1k
http://www.prodigit.net/ClarionDB/print/2004/Nor/6500/DXZ746MP-As_01.jpg
4)1 set of pegasus 6 1/2" component
model PG162P
- selling for 400
can get info from http://www.audiopega.com/
http://www.audiopega.com/New%20Product%201/Com162P.jpg
all item in excellent condition
call or pm me to nego
can get me at 012-3023599
no sms pls
thannks a million
used bout 2 years
sold
Power 12.5 VDCInput
4 Ohm Load250 w x 1
Power 14.4 VDC
2 Ohm Load775 w x 1
just did survey
selling at RM888
come fast fast
model PG162P
- selling for 400
no sms pls
thannks a million
