Interested in ICE but facing problem to setup a high sound quality system within a limited budget? After numerous hours of product matching and optimizing, we have saved all your hassle by providing you these pre-optimized car audio packages.
Stage 1 - Get started, great improvement from your OEM system.
Bi-ampable passive component set for front stage (Either 5.25” or 6.5” Midbass)
2 channel amplifier 200Watt bridged to drive subwoofer (SN-2050)
Boschmann V-10AL subwoofer in ported enclosure (standard)
All this for RM999 only (Original price is RM1320)
Add-on Alpine CDM-9821 CD player at offer price, RM500
Also available 400Watt Amplifier, just add RM238 (SN-2100)
Specially designed comp speakers that can be easily driven by low power amp like HU built-in amps. Hand-matched tweeters and midbass drivers by high resolution measurement equipment. Example system design: the Alpine Cd player 4ch speaker outputs will drive the front components directly and giving you freedom to match the level between tweeters and midbass. The RCA output from the Cd player will be connected to the subwoofer amplifier with lowpass filter set.
Stage 2 – Full Active Optimisation by AvantGarde Engineers
4X50Wrms Amplifier (MGS-8600)
Avant Garde Valeraine VX-2i Audiophile Active Crossover
Upgrade the whole system to full active crossover in competition style and take full advantage of your amplifier power and speaker performance.
Other Alpine CD head units and full set Avant Garde Active Component System also available. All products mentioned are brand new and comes with manufacturer 1 year warranty. For more info or to check out the goods, pls PM or email to me. Questions on system setup are welcome too.
Specifications
Component speakers
5.25” or 6.5” Midbass polypropylene injection cone
100Hz to 2.8kHz Total Variance = +/- 1.5dB
20mm silk dome tweeter
1.8kHz to 15kHz Total Variance = +/- 1.5dB
High efficient passive crossover
Recommended amplification = 50Wrms
Boschmann V-10AL Aluminium Die Cast Heavy Duty Subwoofer
10” Subwoofer Non-pressed Kevlar Cone
450Watt peak power handling
Recommended amplification: 150Wrms
Sensitivity: 93dB 1W/1M
Aluminium Voice coil former
Brand new in Box
Amplifiers
SN-2050 2 channel amplifier
50Wrms X 2 @ 4Ohm
200Wrms X 1 @ 4Ohm bridged mono
SN-2100 2 channel amplifier
100Wrms X 2 @ 4Ohm
400Wrms X 1 @ 4Ohm bridged mono
MGS-8600 4 channel amplifier
50Wrms X 4 @ 4Ohm
200Wrms X 2 @ 4Ohm bridged
Specifications
Component speakers
Brand new in Box
Amplifiers
50Wrms X 2 @ 4Ohm
100Wrms X 2 @ 4Ohm
50Wrms X 4 @ 4Ohm
