*package 3* Night Kids & Jac Audio Sound Quality Full Range Audio System
ICE -In Car Entertainment
jojo9984
5,000 RPM
NIGHT KIDS NKS-C50 5.25" Premium Component Speaker x 1 Unit
Mid-Woofer
Cast Aluminum Basket
Treated and Pressed Paper Cone
Butyl Rubber Surround
Large Diameter Poly/Cotton Spider
Chrome Motor Cover
3” Voice Coil
Aluminum Voice Coil Former
Chrome Push Terminals
4 Ohm System Impedance
Tweeter
25mm Silk Dome
Neodymium Magnet
Ferrofluid Cooled
Crossover
2 Way Passive Network
18dB per Octave Crossover Output
4 Different Attenuation Points
Built In DC/Clip Protection
Selectable 6 or 12dB per Octave Crossover Output
Specification:
Nominal Diameter: 5.25" Speaker
Max. Power: 100W
Frequency Response: 89Hz - 20KHz
Sensitivity (1M/1W): 92dB
Nominal Impedance: 4 Ohms
Voice Coil: 25mm ASV
Magnet: 80mm
Tweeter: 25mm
Crossover: Separate 12dB per Octave
U.S.A Technology
1 Year Warranty Under Local Distributor
NIGHT KIDS NKS-355 5.25" Premium Series Coaxial Speaker x 1 Unit
5.25" Polyethermide dome tweeter
Foam surround
Mica-injected polypropylene cone
Proprietary cold-rolled steel basket
Midrange Diameter: 6.5" Speaker
Midrange Depth: 2.5
Tweeter Diameter: .5"
Frequency Response: 90Hz - 20kHz
Power Handling: 60 Watts RMS
Power Handling: 120 Watts Peak
Crossover High-Pass (HP): 6dB
Sensitivity: 93dB @ 1 watt/1 meter
Magnet: 90mm
Grilles Included
Mounting Hardware Included
U.S.A Technology
JAC AUDIO JA-554 450W X 4 Channel Amplifier x 1 Unit
Norminal Power 75W RMS X 4
Maximum Power: 450W X 4
Full Mosfet Power Supply
4 Ohm Stable Stereo
Variable Low Pass: 30Hz-500Hz
Variable High Pass:30Hz-500Hz
Frequency Response: 10Hz-30KHz
S/N Ratio > 90dB
T.H.D: 0.01%
Two Way Protectioin Circuit
Silver Plated RCA Connectors Screw Terminals
Bridge Mono/ Stereo Output
Double Sided Glass Epoxy Circuit Board
Power Supply: DC 12V
Variable Subsonic Filter
Input Sensitivity: 45dB
4-Channel RCA Input
PWM MOSFET Power Supply
U.S.A Technology
1 Year warranty Under Local Distributorship
JAC AUDIO JA-552 500W x 2 Channel Amplifier
Norminal Power 75W RMS X 2
Maximum Power: 500W X 2
4 Ohm Stable Stereo
S/N Ratio > 90dB
T.H.D: 0.01%
4-Channel RCA Input
U.S.A Technology
1 Year Warranty Under Local Distributorship
NIGHT KIDS NKG-105 10" Precision Series Subwoofer x 1 Unit
Model NKG-105
Nominal Diameter: 10" Woofer
SPL Series Subwoofer
Max. Power: 400W
Norminal Power: 200W RMS
Frequency Response: 43~3KHz
Sensitivity(1M/1W): 87dB
Nominal Impedance: 4ohms
Voice Coil: 50mm
Magnet: 145mm
Double Magnet
Available Configurations: Dual 4 ohm
Xmax (one-way, linear): 0.46"-0.51" (11.7-13.0 mm) depending on specific model
Sealed Enclosure Range : 1.00-1.50 cu.ft. (28.3-42.0 liters)
Ported Enclosure Range : 2.00-3.00 cu.ft. (57.0-85.0 liters)
Shown in Various Car Audio Display Competition
Selling price: RM888
View photo: http://jojo9984.ecrater.com/product.php?pid=1455431
