Zeroed said:Thanks for the bump... the ECU code is 2468. :)
MadCow, what Im selling consists of the ECU, the necessary engine wirings, and the MAF sensor. For the conversion you will need the intake manifold and throttle body as well (Might as well get the 60mm ones for extra power). You should check with your mechanic.
Zeroed said:g88, that Im not sure... but on the ECU casing is a Mitsubishi logo and some MMC wordings, whether APM was a subcontractor or something I dont know. Matching the ECU should be just fine (I've swapped ECUs before), but better check with a sifu first...
MadCow, sorry man I dont have the manifold and throttle body, Im only selling the ECU, Wirings and MAF sensor. If you get the stock 52mm manifold and TB outside, it should cost you between RM200-300. Tell me if youre interested in the set Im having, prices negotiable...
*sorry for posting here but the PM system doesnt seem to be working for me
