4g92(83kw) vs 4g92p(70kw) both SOHC
Sep 27, 2007
4
Does anybody knows the differences between these engines.
MAF is smaller, extractor is diferent 4-2-1 vs 4-1 but that's not all.
thanks
amad108..
416
5,018
never knew it before...
maybe in ecu the most, coz i never found 4g92 engine 4-1 extractor at chop shop, 4-1 normally turbo used right?
i also already 2 time buy 4g92 engine at chop shop, but never found 4-1 extractor..
TheNT
4
It is different in maf.
needs another ecu to work good with different maf.
i changed extractor, ecu, maf and have bigger injectors 210cc but that's not all.
I also put bullet (de-cat), straight flow exhaust, K&N drop in, CAI...
It is better now but not that much. 90 ws 113hp is so big difference :(
Anyone know what next to change :)
Maybe cams are so much different?
I think that first is EURO 1 and second EURO 2 standards, and tjhey changed lot's of that cause of emissions.
zzainudin
503
Subang selangor
got meh 4-1 & 4-2-1 extractor in different spec..
i think this kinda be changes by last owner isn't it
4G92p code create by proton to make is different to mits..btw the both still same
if you study the detail of spec, there are the same
Just my 2 cent :biggrin:
kazami32
33
mitsu & proton spec SOHC 4G92 are same.
but output are slighty different.
theNT:wavey:
cam really make the huge power improve.
beside that.you still had to upgrade many things as well.
espeacially cooling system.
then......
injector you had upgrade...
but you din't upgrade the fuel pump...
this will cause the fuel not enough to
pump into the bigger cc injector.
Shinjite
864
120
1,543
Klang
start from the basics and then u can venture into a world of no returns XD
4G92 SOHC can be upgraded to DOHC and etc or you wanna stay SOHC all the way, not bad I must say :D
wiramax
797
My car 4g92p sohc with cammed. 210cc injector,full exhaust system,4-2-1 extractor, uprated fuel pump, bigger tb & manifolds plu gbox upgrade. Internal still stock, no pnp (in plan) & standard pistons & stndard block(full balanced will be better,).Stock Ecu with rev cut increase to 8k rpm. Plan to install e-manage for future mods. I can say with my current mod, i really satisfied..:) Love the sohc coz low power is great & if u add cam, u will get balanced power.:smile:
wiramax
797
how u increase the revcut just using stock ecu? u increase revcut using what electronic gadget? if not cannot call ur ecu stock la... hehe:hmmmm:
my mech do it for me.( with a cost) it can increase xtra 1krpm per ecu. for example stock 1.6sohc ecu 7472 is 6.5krpm-6.7krpm, after mod it would be 7.5krpm to 7.7krpm rev cut. But mine using 1.8 sohc ecu, its rev higher in std form.Let me noe if u wana increase ur rev cut.i cabn recommend u to my mech.
I just bought a 1992 Mira (Thai-built) 3 cylinder carb with a blown motor. I will be buying a second-hand EFI motor from Japan for it. The shop that will be installing my next motor has warned me to stay away from Turbo motors. Apparently the parts can be expensive and hard to find here in Thailand but I will ask the motor shop if they stock all the parts for these motors as the shop is massive!
I was previously thinking about the JB-DET as it seems to have the most power at lowest RPM, or...
