4g91 Makan Minyak Hitam
rdilaila
haii
enjin nie saya pakai hampir 10 bln, mllge 65K. sejak kblakangan nie minyak hitam kurang byak. dari pemeriksaan sendiri tiada kebcoran pada mana2 bhagia enjin..bleh katakan tip top. ada cek plug semua o.k clean...hanya enapan karbon perang.
so any idea...apa msalah sbnarnya.
if u read the forum rulez... it says english only.
Do you have white smoke coming outta your exhaust? If you do... there's a possibility your piston rings kong. Go try and get a compression test and see.
I think the head gasket is spoil already..laa, my one just replace only ..
check the extractor area, see whether have oil leak out or not...
get a compresion check 1st...then i will know wether izit ur piston ring kong edi...if piston ring kong...bore n dump is 1.6 piston...
Yeah Dude,
Same to me.
i believd our priston is not in good condition.
So, wat to do.
Spend RM to do something la.
Maybe RM 600 to RM 800 kot.
soorryy guys..
thank remind me
however thank alot...l will :ph34r:
wah so fast ur piston ring kong already?
just in one years time?
u must rav it kau kau is it? :P
