that means u r using 82mm piston on ur previous setup which is 1mm bigger than ori 4g92 (mivec or non mivec) thats why the mivec piston is loose inside ur block as it is ori size i guess.. i dont think u wanna use a loose piston in ur block aight.. hehehe..
I heard the mivec piston are hi comp one.. to tell u the truth, my self also not sure what is the compresion ratio of mivec engine.. izit the same or higher than normal 4g92..
