3stage Vtec gear oil
katak_pisang
Selangor
Need help from u guys..
I wonder what is gearbox oil for D15B 3stage Vtec, is it CVTF or ATF?
some mechanic said CVTF and some said ATF..
Thanks in advance
scoupe
1,087
37
shah alam
i think he has a manual box, i have heard of people putting ATF in a manual box. i only gonna assume that was his intention but am unsure though. Btw gunner, is there any real gain from having a 3 stage vtec? im curious. i do apologize because i thought he was talking about stage 3 mods, lols. my bad.
based on his profile photo, maybe it's the old city engine? If so it's an auto.
gunnerzz
Jul 3, 2014
2,109
695
Melaka
Like Izso said, its ancient. I only read abt it as it comes out when my hair is still black and schools are still using blackboard.
Maybe during that time its designed to improve fc esp under normal driving.
From Wiki.....lol
3-Stage VTEC is a version that employs three different cam profiles to control intake valve timing and lift. Due to this version of VTEC being designed around a SOHC valve head, space was limited; so VTEC can modify only the opening and closing of the intake valves. The low-end fuel economy improvements of VTEC-E and the performance of conventional VTEC are combined in this application. From idle to 2500-3000 RPM, depending on load conditions, one intake valve fully opens while the other opens just slightly, enough to prevent pooling of fuel behind the valve, also called 12-valve mode. This 12 Valve mode results in swirl of the intake charge which increases combustion efficiency, resulting in improved low end torque and better fuel economy. At 3000-5400 RPM, depending on load, one of the VTEC solenoids engages, which causes the second valve to lock onto the first valve's camshaft lobe. Also called 16-valve mode, this method resembles a normal engine operating mode and improves the mid-range power curve. At 5500-7000 RPM, the second VTEC solenoid engages (both solenoids now engaged) so that both intake valves are using a middle, third camshaft lobe. The third lobe is tuned for high-performance and provides peak power at the top end of the RPM range.
In newer version of 3-Stage i-VTEC combined VTC and PGM-FI to allow ECU to control full range of mode to archive greater fuel economy improvements and performance. Honda CR-Z able to switch between low-end mode and standard mode from 1000 rpm to 2250 rpm uninterrupted and engage to high cam mode from 2250 rpm upward on SOHC.
  • Like
Reactions: Izso and scoupe
my turbo got break in 29 may(monday)
the total estimate cost for my lost is about 8k
involve part as below:
Haltech E6K most expensive gadget
is hide behond the dashboard and tighten it kao kao by installer with extra nut, they cut the wire so car cant run plus i had wiring all the stuff
kenwood cd player(a bit rosak 1)
my control switch(nos and launch control)
streering they broke it....tend wan to steal
dashboard drawer
new apexi boost meter(white) not more than 1 month
side mirror...
