The defect and its symptom are:
1. Idle with black smoke.
2. Engine jerk when idling.
3. spark plug goes black and after replacement its ok for a while but later will be like running on 3 cyl.
4. Changed plug , running good for a while but the prob comes back.
5. Adjusted Mass Air Flow sensor, defect persists.
6. Problem happened after 6 weeks in the paintshop.
7. Horsy seems to come back everytime you findle with the engine (adjust MAF sensor, change plugs, etc)
This posting was raised by 1Sahar. Lets try help him resolve this issue before he starts changing an engine or do something fishy like adjusting sensors....
Some question,
1. What type of painting did you do? Only external touch up? Did you get the engine bay painted? Did you get the wirings or interior findled with?
2. The idle issue only raises during startup or right until warmup and running around for awhile? Does the defect persist after warm up?
3. Does black smoke persist throughout the engine running period or does it end once the engine is fully warmed up?
4. What fuel are you using? Have you tried the Shell V power? Is it the same? Whats your fuel consumption like?
5. What checks have you done so far, other than findling with the engine? Example would be, have you checked compression? Have you ensured there is no bubble in the coolant? Have you made sure the timing is correct? Have you checked for any diagnostic fault codes? Have you confirmed distributor arm and contacts are not oxidized?
6. How long did you have the car before sending it to the paint shop? Are you sure this occured after the paintshop visit?
7. If you're willing to drive to Nilai, we can meet up with my super mechanic, an aircraft engineer, excellent at diagnostics!! Hahahaha.....
Some question,
