But he does not want to spend any more RM......lol
hammer?? is it bondo? body fillers u can use scraper or brush grinder. don't hammer it.Question : If a ducktail has been moulded to the boot with putty or whatever you call that painters cement, is it easy to remove with a hammer? I want to remove the ducktail but can't afford someone to do it. Besides, should be fun.
don't think so. an angle saw might be easier, but as what LimauKanker said, sanding and touch up needs. it all depends on budgetQuestion : If a ducktail has been moulded to the boot with putty or whatever you call that painters cement, is it easy to remove with a hammer? I want to remove the ducktail but can't afford someone to do it. Besides, should be fun.
just change to a whole new boot, the touch up to get the surface under the putty flawless again will be a pain in the ass.
slowly remove it. dont hammer it off. LOLI just want to break off the ducktail and level the putty. Then slap another spoiler on top so it doesn't need to be flawless, just level and flat
got dremel to borrow ? slowly inching cut it.I just want to break off the ducktail and level the putty. Then slap another spoiler on top so it doesn't need to be flawless, just level and flat
You got angle grinder.....lolI just want to break off the ducktail and level the putty. Then slap another spoiler on top so it doesn't need to be flawless, just level and flat
later he hulk mode he chop off the bonnet.You got angle grinder.....lol
pickup convert. wohooo. first BM 1jZ pickuplater he hulk mode he chop off the bonnet.![]()
If all goes wrong he can change the boot cover like bro. Limaukanker mentioned......hahhahhahahalater he hulk mode he chop off the bonnet.![]()
custom order carbon fibre bonet.If all goes wrong he can change the boot cover like bro. Limaukanker mentioned......hahhahhahaha
need to wear haZMat attire keI happened to have a 2kg or 3 kg hammer lying in the store..been a while since any job i am involved in required it to be summoned.
I do believe that hammer can 'pursuade' the spoiler off your bonet.
Anyway, be very careful with the bondo/body cement...serious injury can occur. Its chemical, handle it with respect.
Putty filler probably should wear face mask and goggles la. Fibreglass base I thinkneed to wear haZMat attire ke
Is not like trying to break some cement plot using heavy hammer. In fact too heavy cannot control the knock.....lolI happened to have a 2kg or 3 kg hammer lying in the store..been a while since any job i am involved in required it to be summoned.
As far as I know putty filler no fiber glass. Unless your car had holes to fill then they use the fiberglass type of paste....Putty filler probably should wear face mask and goggles la. Fibreglass base I think
If i recall correctly apart from being not friendly to our skin, it can cause the victim to be blind. Not sure if it apply for all type or premix type.As far as I know putty filler no fiber glass. Unless your car had holes to fill then they use the fiberglass type of paste....
inhale deeplyPutty filler probably should wear face mask and goggles la. Fibreglass base I think
Whether got fiberglass or not, any dried up stuff, grind into powder who wants to inhale......lolinhale deeply
