Performance tyres for 15"
camp
395
4
Any one here used michelin Pilot Sport 3...any comment?
JINEIL2EN
Over 10,000 RPM!
15,321
525
Island Of Pearl
team99ers.2.forumer.com
kumho ku36 ok kah? 205/50/15 how much ah?
so far i've used AD07, RE001 not bad la...
Now using R888 cannot stand the low thread wear... sigh.
rm250..../pc.
SE86
299
474
1,563
Pilot sport 3 not bad also..tested a friends spectra using this tyres..he bought at rm220 perpiece..good grip in dry and wet..wet tested at genting road..not bad..
camp
395
4
Will take into consideration when next tyre change
S1997
1,001
haishh...life is difficult after ad07 discontinued.
kilang papan now famous for what tyres? :)
koolvibration
186
7
3,018
Garage
federal RS-R or kumho exsta.....buget performance tyre. Federal rs-r is 310 at jooi seng klang....kumho ecsta duno wat price but heard below 300.....
shiroitenshi
3,677
170
with that kind of budget, I'd choose a combo of rear RE001/T1R/whatever tires in the range of RM250+, and Toyo R1Rs for fronts.
You can run a maximum of 205/50R15, but hard to find those tires. RE001 have those sizes, and they're only made in japan, can get, but no shops stock it AFAIK, and the only way is to order beforehand. RE001 in 195/55R15 and 195/50R15 are made in Thailand. Toyo, Recently ordered (4-5months ago, I think) and can get 205/50R15.
205/50R15 and 195/55R15 almost the same size in height, the only difference is the extra 10mm of width.. looks wide when installed on a civic 5th or 5th gen.
Sedan cars, don't use grippy tires at the back... you want a bit of give when doing sharp corners. If using both grippy tires, need to run harder suspension to get the benefit of faster cornering speed. If not, welcome to world of massive understeer.
And if you're that particular about grip, get an LSD. That makes a difference even on standard tires, esp. during wet weather.. nothing is more annoying than having one tyre slipping when going over puddles.
soulV
95
using t1r 195 55 15 before.....good grips wet & dry but too damn cepat habis...currently using federal 595evo price rm200 all inclusive in rawang.....not recommended in wet...(thinking of selling it as >80% still there....anyone?heheh)
Accord80
96
4
3,008
Seattlewangsa
For 205/50/15 tyre, what is their normally price? Planning to change the front tyre (T1R now) with that size. Now running on 195/55/15. Another question, what about the BFGoodrich? Is it okay in terms of performance??
Hello forumers, i have these questions:
1. why do we use coolant + water for the radiator?
2. can i use only coolant, no water?
3. will my cooling system bacomes better n my engine temperature go down more if i use 100% coolant?
4. is it true if we use 100% coolant the radiator tends to crack at the joints n become weaker and prone to clogging? (heard this from few reputable pomen......)
Appreciate all ur feedbacks.:adore:
