Microtech
dear all sifu,
what the impact if the tps reading at microtech handset showed 99%, this reading I get when on the ignition, not start the engine yet..not even press the throttle yet..
I tried to adjust the limit 99% , still cannot get the reading 0% .. does my tps sensor spoil ?
Check connector. The 0-5V is giving full 5V signal. If cannot solve, the check the tps.
anyone could help me on this matter? anyone could offer or have any fren can recommended come and verify this matter? my area is in Cheras bandar Sri permaisuri..I cannot bring the car , because I take out the Throttle body ,I need to calibrate the TPS first before fit the TB.
kes guna modified manifold cam nie ler .. menyusahkan org..
Here the video result
YouTube - 22032010015.mp4
, it showed 99% even not press the throttle. ( engine not start)
does this could be the issues ??
have u adjusted the tps sir?
all friend here, can lt8s use twin relay for fuel pump? now have 1 only. i think my fuel pump dont get smooth current.
power supply to the pump isnt controlled by the ecu sir, its controlled by the relay. go ahead and add another relay for dat peace of mind..
Everytime you remove the TPS you will have to recalibrate it. Assuming that you have calibrated the TPS and it won't show 0%. I am guessing that you have wired your TPS wire incorrectly or TPS sensor is kaputz.
Hi everyone...
As we all know...MICROTECH ECU has been no1 for the past few years in sepang drag battle now..from class B overall champ to class F non vtec and many other events winning non stop..
as part of microtech,we wanna once again congratulate all winners...and thanks for the support all the years...
We will be having a 1month offer for dealers and customers....even tho the australian currency is sky high...we will still maintain the old price to clients and dealers can benefit new dealership scheme...
contact us now!
those who wanna carry this no1 ecu ...can email or call us if interested...
regards
Joshua
www.millennium.my
0123205454
0356334454
[email protected]
did anyone have problem to start car engine when your car parked outside genting highland at night or after rain ? my car failed to start during cold weather
cold start settings not corrected... also most cars fitted with LT10s don't have a cold bypass air valve installed and hooked up. that is the problem.
In LT10s options menu you may want to tune for cold start.
(adj. only the temperature range that is giving you difficulty in cranking and warming up the engine from cold) Eg: 11deg C to 38deg the values should be smooth.
Screen 19 : PumpCold
Screen 20: WATER
Screen 22: CRANK
Screen 28: T Wat
Screen 30: Af_StE
I can't tell you the exact amount you need to configure as these settings and tests requires actual condition. However, some slight guess work could be done to improve the condition.
Another year of drag racing events have just ended..and the microtech ecu has proven again CHAMPIONship of sepang drag battle overall winner for year 2010...
and broken the front wheel drive record with 10.6second (3runs in a row)at sepang drag battle..
microtech the champions choice...
congrats :) to those using the no1 ecu on planet earth!
---------- Post added at 01:48 AM ---------- 6 hour anti-bump limit - Previous post was at 01:43 AM ----------
LT10s the no1 ecu for 4cylinder....
LT16s the no1 ecu for 6or 8cyl.....
hi all microtech sifus,i wanna ask,can mt4 control ignition?as i know it cant,but on my frens car,it shows ignition setup on d lts handset(i1,i2,dwell etc2..)r this functional?thanx 4 any input...
did anyone experiencing fuel pump relay problem when relay running too hot ?
can explain properly is what kind problem? you mean after fuel pump run time too long fuel pressure drop?if wanna solve this kind problem need change your new wring from fuel tank to fuel pump relay
and bigger size wire~
Hi everyone...
contact us now!
regards
Joshua
http://www.millennium.my
0123205454
0356334454
[email protected]
vteck: microtech apa u rekommend for civic saya? mine is EJ with K20A inside. long time tak jumpa, i come see u minggu depan becous my mekanik transplant ada wiring problem want do ecu kasi baik punya
ramadan offer...cash and carry and also with instalation.....
call today....
special offer rb lt16.....
---------- Post added at 12:01 PM ---------- 6 hour anti-bump limit - Previous post was at 12:00 PM ----------
u can visit microtechefi at facebook and click like...
---------- Post added at 12:32 PM ---------- 6 hour anti-bump limit - Previous post was at 12:01 PM ----------
Microtech Malaysia's no1 stand alone ECU............race proven....
