yeah i am aware of the needed mod b4 go to that boost or higher.i have done general overhaul new main bearing,con rod bearing,thrust washer. using l2 carb turbo piston ppl call it piston kepala hitam ( i heard this piston can boost up to 2 bar without sweat..true izit?), metal gasket, head port n polish, grind valve, new valve seal.
n i knew the fuel management must be upgraded too like fuel regulator, bigger fuel pump, air/fuel mngment system n also extra injector.
jineil2en :
wahh 1.8 bar ?? r u using xtra injector ? where do u place it ? try td04-09 from subaru sti,this one can boost up to 1.8 even there's ppl try 2.0 bar.there's oso td04l turbine from pajero diesel, but cannot lawan from subaru one. when ur last time boost up to 1.8, fuel pump oso stock ar? what bout ur fuel mngment..share la fren..
---------- Post added at 08:41 PM ---------- 6 hour anti-bump limit - Previous post was at 08:36 PM ----------
bro, lets try up boost 2gether ha ha..
